Author Topic: What keyboard is this?  (Read 2293 times)
Offline cmadrid
Offline E TwentyNine
    • Some of My Keyboards
Re: What keyboard is this?
« Reply #1 on: Sun, 08 March 2015, 12:34:15 »
Honeywell. I believe they're rubber dome, don't think I've seen one disassembled.  Like the caps though.
Offline cmadrid
« Reply #2 on: Sun, 08 March 2015, 12:40:19 »
Thanks ;)
Offline cmadrid
« Reply #3 on: Sun, 08 March 2015, 12:40:53 »
Yea, the caps do look pretty nice
Offline orihalcon
« Reply #4 on: Sun, 08 March 2015, 15:20:00 »
Anyone know if these could be Hall Effect?  Never had a Hall Effect board in hand, but I think most state "micro switch" on the back.
I have one in the mail that I think is a Hall Effect board, but have not received it yet to know for sure, but the caps do look similar in shape and font:
http://www.ebay.com/itm/331486223041
That one also says Assembled in Mexico, so I'd say there's still a chance that these could be Hall Effect as well maybe and they just left off the "Micro Switch" part?
Seller just needs to pull a cap to tell us more.
I still haven't heard about a reliable (at least easy to implement) modern controller for Hall Effect boards, so having one like this that already outputs AT or XT that can be converted with a Soarer's Converter would be AWESOME.
« Last Edit: Sun, 08 March 2015, 15:22:31 by orihalcon »
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Sun, 08 March 2015, 15:23:31 »
Anyone know if these could be Hall Effect?  Never had a Hall Effect board in hand, but I think most of the Honeywell ones state "micro switch" on the back.
If you only had the terminal those things attached to.  You can determine what speed/protocol the keyboards used.  Usually VT type serial.  (If they are not AT or XT)
« Last Edit: Sun, 08 March 2015, 15:26:18 by Snowdog993 »
Offline orihalcon
« Reply #6 on: Sun, 08 March 2015, 15:38:17 »
Ok, so some more research indicates that pretty much all of Honeywell's boards were made in Mexico, and most of the Honeywell boards on ebay have similar fonts and caps, so I guess that might not count for much, could still be though.  Looks like 3 have sold so far and there were originally 50 available, so if someone gets one, they'll have to let us know!
Offline Snowdog993
« Reply #7 on: Sun, 08 March 2015, 15:49:08 »
I am pretty sure it is AT.  If you look at the template on it, it is for MS word.  Since it has Num and Scroll lock key indicators, it is probably an AT keyboard with an XT layout.  That is my guess.
« Reply #8 on: Sun, 08 March 2015, 17:43:29 »
I can pretty much guarantee that it's rubber dome and Honeywell.  I've seen that board pop up a few times and went searching for info on it.  All things point toward RD.
« Reply #9 on: Sun, 08 March 2015, 18:09:01 »
I got the seller to send me a picture:
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?topic=63161.0
« Reply #10 on: Tue, 10 March 2015, 15:04:16 »
It has very old adaptor. It should has long history.
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
