Author Topic: Why are KeyCaps and KeySets SO EXPENSIVE?  (Read 14537 times)
Offline techy1
  • 10101010101
« on: Sun, 08 March 2015, 20:33:41 »
Hey guys. I was just wondering... Why are keysets (mainly) like bumblebee, broset, cherry replica, etc so expensive. Some keycaps are also quite expensive. Just wondering why this is. Thanks!
 :thumb:
Re: Why are KeyCaps and KeySets SO EXPENSIVE?
« Reply #1 on: Sun, 08 March 2015, 20:46:16 »
It costs a lot for manufactures to print them. Signature Plastics, GMK, etc  Same with Keycaps, materials for mold, cast, supply demand, etc.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #2 on: Sun, 08 March 2015, 20:49:38 »
dem limited runs
« Reply #3 on: Sun, 08 March 2015, 20:54:56 »
The more you buy, the cheaper it gets.  Unfortunately GH is not exactly a bulk wholesaler, and usually manages a couple of hundred sets, which is not usually not enough to qualify for any particular discount from the manufacturer.
The cheapest set I have seen is Tai Hao ABS doubleshot OEM profile.  The original set cost $6.50, but that was bumped up to $9 to include 1.25x modifiers and a standard 6.25x space bar.  Later Tai Hao GBs came in at $12 or something.
Offline ideus
  • Björkö.
« Reply #4 on: Sun, 08 March 2015, 21:07:34 »
You are referring to some of the highest quality sets, like GMK, and some SP that are also not cheap. But, there are low cost sets, that are not even considered to be offered in sites like this, for example some lasered thin ABS.
In general the high cost of manufacturing of quality keycaps is what made them economically unfeasible with the cost reduction trend of input devices. It happens the same to the switches technologies that moved from complex discrete mechanical designs like cherry, to low cost mechanisms that use a rubber mat with domes and metal bubbles to replace the discrete switch technology with great savings.
In summary, the keyboard enthusiasts, by definition, are willing to pay hefty prices for high quality components, that the rest of the people consider outrageous due to the cheapo option in keyboards.
« Reply #5 on: Sun, 08 March 2015, 21:55:39 »
dem limited runs
*Cough Cough*
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #6 on: Sun, 08 March 2015, 21:59:08 »
dem limited runs
*Cough Cough*
the amount of things i would swallow for one blank Realforce set...
Offline ghostjuggernaut
« Reply #7 on: Sun, 08 March 2015, 22:51:33 »
dem limited runs
*Cough Cough*
You and me both.
« Reply #8 on: Sun, 08 March 2015, 22:58:38 »
Me tooooooooooooooooooooo  ^-^
« Reply #9 on: Sun, 08 March 2015, 23:09:51 »
*Cough Cough*
Yeah, but those were made in Japan. Topre keycaps are like square melons.
Offline Korth
« Reply #10 on: Sun, 08 March 2015, 23:19:26 »
You would think wider adoption of 3D printing tools would make small production runs less costly?
I expect the material cost to be something around $0.05 worth of plastics.  Its the labour we pay for, the person doing the physical work on each chunk of plastic.  (Dunno why, since Foxconn slave labour gets paid less than $0.05 anyways, but thats a different issue altogether.)  But the labour cost is minimized once the automation kicks in, any decent CNC/3DPrint setup should be able to spew forth tons of one-of-a-kind pieces along a programmed script, no?
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #11 on: Sun, 08 March 2015, 23:21:14 »
Most caps are injection molded. I doubt many 3D printers are able to match the quality that GMK provides.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #12 on: Sun, 08 March 2015, 23:44:21 »
The fincancial cost to purchase, install, setup, program, and maintain those machines, molds, software gets to astronomical numbers very fast.  On top of the only reason those companies are even in business anyway, profit.
As I side note, I install and fix machinery in manufacturing facilities.  One of my last projects was installing a new mold pouring line at a John Deere Foundry.  That project was estimated to cost Deere about 25 million dollars.  Thats just the price to purchase and install the equipment, let alone molds, materials, consumables, power to melt that much iron, etc, etc.
For the record molds for caps at Signature Plastics are in the realm of $5,000 each.
« Reply #13 on: Mon, 09 March 2015, 01:16:58 »
You guys can swallow what you like, and I'll collect the printed sets :p
Offline phoenix1234
« Reply #14 on: Mon, 09 March 2015, 01:22:12 »
 :thumb:
I like linear switches
Offline Sed8op8
  • Keyboard Padawan
« Reply #15 on: Mon, 09 March 2015, 05:02:00 »
dem limited runs
*Cough Cough*
Hey Dustin where EXACTLY do you live I'm going to be headed through MN and I would love to drop by and cough...cough... Say hi yes that's it i would like to chat  :thumb: j/k you always have the craziest stuff good sir. Do you mind if I ask what your profession is? Anyways beautiful pics and gear as ALWAYS. Don't mind me I'm just spoon deep in a jar of smuckers. Love it  :eek:
Offline wade_blanshard
« Reply #16 on: Mon, 09 March 2015, 05:51:01 »
dem limited runs
*Cough Cough*
Good God. That's so nice. ;-;
Offline foxer
  • Formerly wadeu
« Reply #17 on: Mon, 09 March 2015, 05:52:51 »
Okay, that post above was me. I didn't realise I made a separate account for tapatalk. I'm dumb.
Unbowed, Unbent, Unbroken.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #18 on: Mon, 09 March 2015, 06:55:37 »
Reported j/k
|||My other keyboards :
x
Offline techy1
  • 10101010101
« Reply #19 on: Mon, 09 March 2015, 15:11:39 »
Thank you guys for all the responses. I was looking into buying some keysets but they are so freaking expensive!
Offline ideus
  • Björkö.
« Reply #20 on: Mon, 09 March 2015, 16:45:51 »
If your reference are rubber dome keyboards yes. Maybe, you should give a second thought on considering this hobby.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #21 on: Mon, 09 March 2015, 17:54:34 »
Keep in mind that the past few years GMK and custom SP legends have become much more readily available. Usually companies order those keysets at much larger numbers and often in standard colours meaning better prices. Before group buys were a thing we couldn't even get our hands on Cherry/GMK keys because it took us a while to find the place that bought the old machinery and was using it now.
Single novelty caps at $4-8 a piece from SP were the norm. Imagine paying $400+ for a DCS keycap set from Signature plastics!
We as a community managed to make this hobby more affordable. What you are also experiencing is wanting to be part of the 'old boys' that have all the cool stuff from years of collecting.
Don't. Even if it only for your wallet. ;)
In any standardized production environment the expensive part is when you have to stop the machines, clean them and prepare everything for another run. And even at 300 keysets, we are a limited run. :P
We are the freaks that have to have the non-standard colours, extended layouts or NEED that special combo here and there.
« Last Edit: Mon, 09 March 2015, 18:02:47 by JaccoW »
x
Offline Huxley2500
« Reply #22 on: Mon, 09 March 2015, 18:54:12 »
Supply and demand.
« Reply #23 on: Mon, 09 March 2015, 18:57:36 »
Supply and demand.
For resale.  For new caps it's economies of scale.
Offline rsac
« Reply #24 on: Tue, 10 March 2015, 23:33:39 »
Heh, I was about to make the same topic, but then got derrailed. Good that I looked again before making a duplicate one.
So, where can I find cheap keycaps sets for making a custom keyboard? Because, besides the case, they seem to be the largest single cost. I did not expect that. A single mx-compatible keycap set is more expensive than my entire keyboard everwhere I looked. Even a blank one at Signature Plastics. And it is not because I'm buying too little, because I bought only one of my keyboard too.
And I've not found any keycaps for matias switches, so I guess they are not suitable to build a custom keyboard... The quiet click ones sounded nice, but I guess the cheap gateron browns will make do, and maybe even better for me.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #25 on: Wed, 11 March 2015, 05:06:21 »
You could take a look at Tai Hao caps.
Alps are currently limited to vintage sets.
EDIT:
These Tai-Hao sets are available on MK.com. Roughly $49 per set with free shipping.
In a GB some sets can be as cheap as $15.
If that is still too pricey... you might have picked the wrong hobby. :P
I could give you a more technical explanation why a GMK is more expensive than Tai-Hao or Signature Plastics if you want. ;)
« Last Edit: Wed, 11 March 2015, 10:10:21 by JaccoW »
x
Offline Oobly
« Reply #26 on: Wed, 11 March 2015, 08:24:39 »
The Keyboard Co now lists Matias keycaps on their site: http://www.keyboardco.com/index.asp
Can't remember who their partner is on the other side of the ocean, but they most likely will also start to stock them. Not a lot of options (white or black only so far), but at least it's something.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Data
« Reply #27 on: Wed, 11 March 2015, 11:55:03 »
Supply and demand.
Yep.  This exactly.
The solution is to get more people interested in custom/customizable keyboards.  As the hobby grows, economies of scale will allow prices to go down naturally.
Offline rsac
« Reply #28 on: Wed, 11 March 2015, 17:29:16 »
EDIT:
Thanks, on mechanical keyboards there are even cheaper sets than the Tai-Hao and the ones I saw on Signature Plastics. Still kinda pricey. But the GB set is a better price for sure. I guess there is no way around the economies of scale. I will probably wait some more to see what will come out of Axios and Keyboardio croudsourcing, or if there is a new GB like the one you linked.
And I don't plan to buy those things frequently. Even the "cheap" stuff seems made to last for quite a while, and the modularity of the keyswiches and controller, etc, means I can aways replace just the part that became problematic. I'm actually more worried about the possible time I will spend hacking keyboard firmwares.
Thanks, I'm looking for boring sets. But I think this round was won by cherry compatible swiches, for me. I hope in some years those matias swiches and keycaps will be more accessible, as the connector between them seems a simpler and better design than the cross shaped cherry mx stem.
