Author Topic: What does "Mechanical" mean?  (Read 13948 times)
Offline msiegel
« on: Mon, 31 August 2009, 21:59:29 »
Our beloved mechanical keyboards have only one thing in common...
Something that "other" keyboards don't have...
Metal springs :)
True, or false?
Offline wellington1869
« Reply #1 on: Mon, 31 August 2009, 22:13:44 »
the way we've used the word "mechanical" on gh, it seems like all we mean is "does something different from logitech and microsoft" :)
maybe metal springs is the only common factor?
using: ms 7000/Das 3
Offline rdh
« Reply #2 on: Mon, 31 August 2009, 22:32:23 »
False, I'd say.
I draw the dividing line between switches that require bottoming out (rubber domes and other more or less pure membrane boards) and those that don't, though I suspect not everyone will agree.
Which could be taken as another way to say "does something different from logitech and microsoft", I suppose.  :-)
For example, I have an old Key Tronic here with buckling sleeves and capacitive switches, but I consider it mechanical.  It has but one spring, which is on a key that's intended to be harder to press than the others.
EDIT: Removed extraneous word.
« Last Edit: Mon, 31 August 2009, 22:47:27 by rdh »
at home: IBM "Space Saving" Model M
at work: Topre Realforce 87UKB55
Offline timw4mail
    • https://timshomepage.net
« Reply #3 on: Mon, 31 August 2009, 22:47:33 »
Bottom out makes sense, but I like to think that each key has an individual switch, as well.
Although it's kind of a gray area with the membrane Buckling springs, this seems to me to be the most differentiating factor of "mechanical" keyboards.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline rdjack21
« Reply #4 on: Mon, 31 August 2009, 23:04:31 »
I think the no Bottom out option is the best. You can't really say individual switch because even crappy rubber dome boards have a individual switch on each key (its the dome under every key). But even on the the Bottom out type of boards there are a few that are decent to type on.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdh
« Reply #5 on: Mon, 31 August 2009, 23:06:57 »
Quote from: timw4mail;113561
To me, the switch is the electrical contact - the thing that shorts the row trace with the column trace.  (I have a pretty literal mind.)   In that sense, membrane and rubber dome boards do have switches and capacitive keyboards don't (excepting the DIP switches), which is why I draw the line where I do.   (I'm a Topre fan, wouldn't want to exclude my own favorite. :-)
What I think you're saying is that each key is built out of it's own individual parts (beyond the key cap and maybe a plunger). Is that more or less it?
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #6 on: Tue, 01 September 2009, 02:57:26 »
In the old days, a keyboard was "mechanical" if it didn't involve a non-mechanical step in the key action.
So a Hall-effect switch wasn't mechanical, because it used an electronic chip to detect a magnetic field. Capacitative switches would also be considered electronic, since you needed electronics to generate the high frequencies used to measure capacitance. A reed-relay switch would be a borderline case.
Both of those, of course, had metal springs to return the keys back to position.
And, by this criterion, a rubber dome contact switch would be mechanical. But the first touchpanels were capacitative. Still, one usually thinks of something as "mechanical" more readily if it has metal moving parts, like an alarm clock... or a Cherry or ALPS switch.
So the term "mechanical", as it is now used, is something of a misnomer. The main distinction between the switches called mechanical, and those that aren't, though, could well be the metal springs these days - because flexure in a rubber sheet leads to much shorter life than flexure in a metal spring, 10 million instead of 50 million keypresses.
So one has the rubber dome switches at the short lifespan end of the spectrum, mechanical switches in the middle, and the older expensive (but not tactile) technologies like reed relay and Hall effect provide the longest lifespan.
Offline itlnstln
« Reply #7 on: Tue, 01 September 2009, 07:48:41 »
When I first joined GH, a lot of us at that time suggested that the BS assemblies (both M and F type) were not true mechanical switches since they do not make a mechanical connection to send a signal. The same could be said for Topre switches. Personally, I try to avoid the term "mechanical" when describing good keyboards since you tend to get people on either side of the fence arguing that a particular switch is or isn't mechanical (along the lines of what quadibloc said). I try to use "quality" instead of "mechanical" since it's not as specific.
Offline lowpoly
« Reply #8 on: Tue, 01 September 2009, 07:54:19 »
Every switch is "mechanical". The only non-mechanical keyboards I can think of right now are those laser phone keyboards. Edit: and all those on-screen variants.
As soon as you move away from this it becomes a matter of definition.
Here on GH, at least a year ago - like itln mentioned - it was a code for switches with metal to metal contacts.
« Last Edit: Tue, 01 September 2009, 08:00:13 by lowpoly »
Offline ch_123
« Reply #9 on: Tue, 01 September 2009, 08:41:09 »
To me, a 'Mechanical switch' is one of the three main types of contact mechanism - each key has it's own self contained electrical switch, and depressing it causes two metal electrical contacts to come together. This is in contrast to a membrane or capacitive keyboard.
But yes, I'd also use it in reference to what would be better referred to as 'High quality' keyboards.
Offline cmr
« Reply #10 on: Tue, 01 September 2009, 09:34:49 »
i would define the term as follows.
mechanical keyboards include those which employ individual moving assemblies in which two conductors make a physical connection to complete a circuit, thus signaling to the keyboard controller that a key has been pressed.
the term is also applicable to designs which utilize mechanisms to provide haptic or aural feedback, even when there is no mechanical contact utilized in the circuit.
Offline rdh
« Reply #11 on: Tue, 01 September 2009, 09:53:02 »
Quote from: itlnstln;113611
Yeah, that makes a lot of sense.
Not all mechanical key mechanisms are acceptable (e.g. the "Mechanical Touch" buckling spring boards have a pretty low reputation), and not all rubber-dome boards are made of concentrated evil.
As I admitted above, my definition is partly drawn so as to keep my current favorite key type on the "right" side of the fence.   (I came up with it while trying to classify a certain cheap-but-clicky board I bought in a thrift shop.   Still gotta post about that one.)
Offline lowpoly
« Reply #12 on: Tue, 01 September 2009, 09:56:00 »
Quote from: cmr;113631
That would include every rubber dome but exclude the Model F.
I think the 'contains metal spring' suggestion from the OP is quite clever, even if it includes a few variants that would be frowned upon here. Like the C64 keyboard for ex.
« Last Edit: Tue, 01 September 2009, 09:58:59 by lowpoly »
Offline cmr
« Reply #13 on: Tue, 01 September 2009, 10:19:06 »
i guess the membrane layers are technically moving, but they are not individual assemblies.
Offline huha
« Reply #14 on: Tue, 01 September 2009, 10:37:09 »
Quote from: lowpoly;113636
... and the beloved Fujitsu Peerless.
I'd go a step further and like to demand the spring has to actually be part of the key action. The Topre spring is mainly just there to change capacitance.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
« Reply #15 on: Tue, 01 September 2009, 10:38:09 »
What about rubber dome boards that use some sort of slider between the key and the dome?
Offline Rajagra
« Reply #16 on: Tue, 01 September 2009, 10:53:10 »
I would like to say that a mechanical keyboard is one where the switches are engineered; designed to register a keypress in an efficient manner.
As opposed to lowest common denominator keyboards which are included almost as an afterthought, matching the way they are designed primarily to be cheap and the method of registering a keypress also seems to be an afterthought or lucky coincidence.
It may not be a literal definition, but it's how I like to think of it.
Offline timw4mail
« Reply #17 on: Tue, 01 September 2009, 11:56:10 »
With the exception of the Buckling spring mechanisms, I would define it as a keyboard that contains high-quality individual self-contained keyswitches, that offer some sort of quality and comfort advantage over a traditional keyboard.
Or in general, a keyboard that has better feedback and reliability than your run-of-the-mill keyboard.
Offline msiegel
« Reply #18 on: Tue, 01 September 2009, 12:44:25 »
Quote from: ch_123;113652
:D hmm... on one hand you might not have to bottom them out...
but on the other hand they don't have a metal spring
by my criterion, they're not "mechanical" :)
Offline msiegel
« Reply #19 on: Tue, 01 September 2009, 12:49:57 »
Quote from: ripster;113711
Mechanical means expensive.
hey, i bought a model m mini for $8
it was a fixer-upper :)
Offline itlnstln
« Reply #20 on: Tue, 01 September 2009, 13:03:59 »
My definition is similar to that of quadribloc's (if I understood correctly).  To me, "mechanical" means a metal to metal contact.  Thus, Alps, Cherrys, SMKs, Mitsumis, etc. are mechanical.  Rubber domes, membranes, capacitives, etc. are all "electric" switches.  Thus, BS, Topres, rubber domes, etc. are not mechanical.  Neither definition assumes a particular quality-level.  Either can be excellent or crappy.  I, personally, focus on "quality" keyboards than a switch definition.
Offline Rajagra
« Reply #21 on: Tue, 01 September 2009, 13:43:24 »
How about this straight definition of mechanical: "done by machine."
In cheap and nasty keyboards the user pushes parts together and simple proximity creates the electrical contact which results in key recognition.
In mechanical keyboards the process is indirect: you provide force to a simple machine - a set of linkages, levers or whatever - any piece of engineering that actively governs the progress of movement and determines when actuation takes place.
Offline timw4mail
« Reply #22 on: Tue, 01 September 2009, 13:56:28 »
Quote from: Rajagra;113738
In other words a mechanical switch is a switch with a length-reducing leverage assembly. That definitely makes sense.
Offline msiegel
« Reply #23 on: Tue, 01 September 2009, 14:10:35 »
you guys are brilliant, i'm glad i posted this question :D
Offline msiegel
« Reply #24 on: Tue, 01 September 2009, 14:46:51 »
say... that would also mean that IBM models M and F *are* mechanical:
their spring/hammer assemblies act as levers to press the membrane switches :)
