Author Topic: Modernizing Hall Effect: 60% layout with custom Korean case  (Read 3251 times)
Offline Firebolt1914
  • POM Overlord
« on: Tue, 10 March 2015, 14:09:13 »
This is going to be my build log on geekhack; a similar log with different questions will also be on DT.
My plan is to make a pcb, tinker with my layout that is similar to a 60% keyboard, and possibly commission a case from a Korean custom kbd maker.
Currently, I'm trying to figure out how to use kicad, and I'm creating a PCB. I'm also in need of a spacebar :blank: so if anyone wants to help make a spacebar in CAD so I can 3D print it, that would be amazing.
The story:
I've acquired 2 Hall Effect keyboards on ebay with caps that are in fairly good condition. After going over the matrix with a few people, we concluded that it is 1KRO: something that I do not wish to use. HaaTa suggested that I make a custom PCB. At first, I didn't want to go through all the effort, but when I realized how badly I wanted to use Hall Effect switches, I decided to go all out. A full Korean custom case with a modified 60% layout.
« Last Edit: Wed, 11 March 2015, 13:57:59 by Firebolt1914 »
  • POM Overlord
Re: Modernizing Hall Effect
« Reply #1 on: Tue, 10 March 2015, 22:43:19 »
Alright, kailet said that if I send him the PCB files, he can make a case for me :eek:
This dream is slowly coming together
Re: Modernizing Hall Effect: 60% layout with custom Korean case
« Reply #2 on: Wed, 11 March 2015, 09:49:00 »
Pretty interested in this but there's not enough to read! Do you have a link to the DT thread?
  • POM Overlord
« Reply #3 on: Wed, 11 March 2015, 13:46:06 »
I'm just getting started. The DT thread is about the same length too. Will edit both of them
Offline jacobolus
« Reply #4 on: Wed, 11 March 2015, 16:23:32 »
Before pics?
Offline heedpantsnow
  • Old enough to know better
« Reply #5 on: Wed, 11 March 2015, 20:02:11 »
Oh my how I love stuff like this. Building one-of-a-kind awesome gear!
I'm back.
« Reply #6 on: Wed, 11 March 2015, 20:20:03 »
Awesome idea, I'm really interested to see how this goes.
Offline njbair
    • nickbair.net
« Reply #7 on: Wed, 11 March 2015, 20:55:43 »
This sounds like a really neat idea. I don't know a lot about hall effect keyboards. Are there standard switches, springs, or caps for this kind of board or are you basically winging it with discrete components?
My boards:
  • POM Overlord
« Reply #8 on: Wed, 11 March 2015, 21:00:24 »
There are standard switches and all, but they're from a while ago, so I have little to work with.
« Reply #9 on: Wed, 11 March 2015, 22:02:11 »
I like the layout, making use of those extra keycaps.
Note: this style of shuffling around the keys to make a more usable layout only works with "single magnet" or "sealed" switches. The old "dual magnet" types are limited by the "finger" plate they have available. Sealed switches need a custom plate of course but it's possible to make any layout you have the keycaps for.
also forget DT: you have more HE expects here anyway.
@njbair: SP can make keycaps with hall effect stems, though I think it's limited to SA (SA profile was most likely based on these hall effect caps)
I lubed up a hall effect board and a few GHers got to try it. It's very linear!
