Author Topic: My Friend Jens 3D Printed a Few Designs  (Read 2435 times)
Offline SirChurch
« on: Wed, 11 March 2015, 02:27:31 »
Jens is a pretty talented artist and he happens to own a formlabs Form 1+ 3D printer. I nabbed an open source skull keycap STL here: https://github.com/kekstee/3dprint. I was pretty pleased with the first printing attempt so much that it is now my ESC key (album: http://imgur.com/a/jJqKw).
Jens took a few weeks and decided to make some caps of his own design. Album: http://imgur.com/a/DEtdZ
What do you think?
Currently typing and gaming on a Poker II MX Clear
 ┬━┬ノ( º _ ºノ)
Offline PauloF
Re: My Friend Jens 3D Printed a Few Designs
« Reply #1 on: Wed, 11 March 2015, 07:11:07 »
I really love the details... man i wish i had a 3d printer  ^-^
They seem a bit fragile for an everyday use that can ruin them though.
« Reply #2 on: Wed, 11 March 2015, 09:46:44 »
I mean if you're printing with ABS, the caps should be durable PauloF.
Did you do any acetone smoothing SirChurch or Jens? The finishes on the caps look pretty good :).
« Reply #3 on: Wed, 11 March 2015, 10:55:52 »
The printer used is an SLA printer.
I'm not a huge fan of the designs, but they did print well.
Offline radish
« Reply #4 on: Wed, 11 March 2015, 22:53:08 »
You can always cast them. They would be durable enough then.
LZ CP
