Author Topic: Switch from azerty to uk qwerty corsair vengeance k70  (Read 2600 times)
Offline vanhoutte
« on: Wed, 11 March 2015, 05:25:20 »
Hello
In belgium we use azerty and for work i changed to qwerty so i just changed my keyboard on my pc.
That is fine but i'm not used to the special characters yet so i'd like to change the keys for all my numbers etc.
I have a corsair vengeance k70.
I tried contacting support but they cannot replace my keys only a couple of them.
Any suggestions?
Kind regards
VanHoutte
Offline Oobly
Re: Switch from azerty to uk qwerty corsair vengeance k70
« Reply #1 on: Wed, 11 March 2015, 08:22:06 »
It's a bit hard on that board since it doesn't have a standard layout, so a "normal" QWERTY UK ISO set won't fit. If you don't mind that they're a slightly different font / profile you could buy a full set of UK ISO keycaps and replace either just the top row or the whole board except the bottom row.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline vanhoutte
« Reply #2 on: Thu, 12 March 2015, 09:35:24 »
I see
Well it's kind of a shame they would be different that the other keys. I guess  ill just stick to my azerty layout or try to find someone with a broken corsair qwerty keyboard :p
Thanks tho
