Author Topic: Plate editing help needed  (Read 1706 times)
Offline neverused
« on: Thu, 12 March 2015, 12:12:26 »
I made a plate using swill's tool but need to edit the line color of the svg and ensure the dimensions are in mm. Since I don't have access to inkscape on my work laptop and my personal computer is out of commission for the moment, is there anyone with a program and ability to change all the lines to:
R:0
G:0
B:255
a:255
in an svg file for me? Also if you could check that the units are mm, that would be great.
Thank you so much for your help!
Offline neverused
Re: Plate editing help needed
« Reply #1 on: Fri, 13 March 2015, 03:10:13 »
Nevermind, I worked it out with a portable apps version of inkscape and librecad
« Last Edit: Fri, 13 March 2015, 08:47:58 by neverused »
