Author Topic: My 60% Orange Alps m0118 project  (Read 38560 times)
Offline Yoe
  • Alps & ISO <3
Re: My 60% Orange Alps m0118 project
« Reply #50 on: Thu, 02 April 2015, 02:28:07 »
Hmm... If someone mass-produced it with same keycaps, Matias click switches and wooden case... It'd be cool.
How about a Poker case compatible (I assume the keyboard size fits.. haven't checked) pcb and plate (both ISO and ANSI versions), Matias switches and a bunch of different cases to choose from? I'd like that. The only tough part for mass production I guess is the keycaps. A lot of M0118s and M0116s would have to go to slaughter if they can't be replicated somehow.
Offline jacobolus
« Reply #51 on: Thu, 02 April 2015, 02:42:15 »
How about a Poker case compatible (I assume the keyboard size fits.. haven't checked) [...]
No, it’s a different size. However, the alphanumeric block of an M0115 or M3501 *is* compatible. See hasu’s PCB, https://geekhack.org/index.php?topic=69740.0 (The ISO-layout M0117 / ISO-layout AEK IIs are also the right overall size, but everything is shifted over by a quarter unit, so they need their own new PCB).
Offline Yoe
  • Alps & ISO <3
« Reply #52 on: Thu, 02 April 2015, 03:07:42 »
Ahh… you're right. I can see that now. Thanks! Putting the cases back on the list of stuff that would have to be made then :)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #53 on: Thu, 02 April 2015, 03:40:55 »
This has to be my favorite board I've seen on here. 10/10, I want this so badly I don't have words.
Brilliant job.
Offline Yoe
  • Alps & ISO <3
« Reply #54 on: Thu, 02 April 2015, 04:46:57 »
Brilliant job.
Wow.. thanks! :D
Offline Zeroo
« Reply #55 on: Thu, 02 April 2015, 07:25:36 »
Wow! Job well done! :)
Offline Yoe
  • Alps & ISO <3
« Reply #56 on: Fri, 17 April 2015, 01:15:46 »
Time for an update :)
I made this mouse to go with the keyboard. Basically a modified Logitech mouse fitted with a micro usb jack in the front and housed in a piece of oak wood. One mouse button/scroll wheel is all I need :)
« Reply #57 on: Fri, 17 April 2015, 02:10:18 »
Nice mouse :)
How do the buttons work?  Nothing obvious is visible.
Offline Yoe
  • Alps & ISO <3
« Reply #58 on: Fri, 17 April 2015, 02:42:29 »
Nice mouse :)
Thanks :) I have removed the left and right mouse button switches and wired the scroll wheel button to be the left and only button. I always ctrl-click instead of right click. Old habits die hard. But I do use the scroll wheel a lot, so this was the obvious solution to make the mouse look clean.
Offline Yoe
  • Alps & ISO <3
« Reply #59 on: Wed, 29 April 2015, 09:57:04 »
No more cutting up M0118 keyboard plates for 60% Alps boards! The brother of a friend of mine was kind enough to cut a bunch of replicas on the laser cutter at his workplace. I got one measurement for the cylindrical stabs a bit tight, but nothing a bit of dremel work couldn't fix :)
« Reply #60 on: Wed, 29 April 2015, 09:58:46 »
Oh ****. Those plates are looking really good!
Offline mougrim
« Reply #61 on: Wed, 29 April 2015, 11:13:05 »
Now we need PCB and case schematic :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Yoe
  • Alps & ISO <3
« Reply #62 on: Wed, 29 April 2015, 12:47:26 »
:) Yeh, I was not really expecting them to come out like this.
Yup. Case plans, _that_ I could provide, but PCB plans… gonna need some help with that. I'd like something simple that anyone could make at home. Like.. single sided with holes to solder a teensy in directly. It could be a nice kit, or I could do the artisan thing and build these or parts of the assembly for people.. I don't know. But a PCB design would be nice, I agree.
Offline Yoe
  • Alps & ISO <3
« Reply #63 on: Tue, 05 May 2015, 12:51:29 »
Next iteration: tactile brown Alps :)
« Reply #64 on: Tue, 05 May 2015, 12:53:30 »
Ugh I wish I had enough to fill out a 60% board...
Offline morpheus
« Reply #65 on: Tue, 05 May 2015, 22:19:29 »
OMG, this is beast!!!!!
Just out of curiosity, how much would you charge for making a TKL Brown ALPS?
Offline Yoe
  • Alps & ISO <3
« Reply #66 on: Wed, 06 May 2015, 01:28:55 »
I feel you bro. But you still got the blues... :)
Well... it was hard enough to find brown Alps enough to fill a 60%, so finding enough for a TKL would really take some effort. I don't think I'd even do this for money... ><
Offline Yoe
  • Alps & ISO <3
« Reply #67 on: Thu, 07 May 2015, 05:02:00 »
Progress update...
Dyed keys. Elephant gray modifiers (kinda blue-ish).
Offline azhdar
  • Praise the AZERTY god
« Reply #68 on: Thu, 07 May 2015, 05:05:50 »
Progress update...
looks really great.
Azerty Propagandiste
Offline Fullcream
« Reply #69 on: Thu, 07 May 2015, 05:52:20 »
Love your work dude! Inspiring me to cut up some old Alps boards.
Offline Yoe
  • Alps & ISO <3
« Reply #70 on: Thu, 07 May 2015, 09:31:51 »
Thanks, mate! Just do it :)
Progress update...
looks really great.
Offline zombimuncha
« Reply #71 on: Thu, 07 May 2015, 12:15:52 »
Progress update...
dayumn that looks great!
Can you share dye name/labels times and temps?
Offline Yoe
  • Alps & ISO <3
« Reply #72 on: Thu, 07 May 2015, 13:14:06 »
Progress update...
Thanks :) I used Dylon Multi-Purpose Dye, 21 Elephant Grey and 09 Pagoda Red. I don't have exact times, but these two take pretty fast. I'd guess three minutes for the gray and maybe five for the red. Just take one key cap up and rinse in cold water real quick to check the color every minute on these until you get the right hue. The gray one is a bit harder to get right, but just watch them and you'll be ok. I kept both dye baths near boiling or boiling all the time. Stir, stir, stir... When they are done, rinse carefully and wipe them to remove residual dye splotches if any. Oh, and don't forget to post pictures when it's finished :)
Offline andCoffee
« Reply #73 on: Thu, 07 May 2015, 17:17:48 »
Are you selling plates by any chance?  This layout is the one that has made me want to try 60%.  I could never get over giving up on the arrow keys.
Offline Yoe
  • Alps & ISO <3
« Reply #74 on: Fri, 08 May 2015, 01:23:40 »
I've got a spare or two... PM me :)
Offline andCoffee
« Reply #75 on: Fri, 22 May 2015, 16:12:20 »
Thanks.  However I ended up doing some research on how difficult it would be to get keycaps and just ended up buying an M0116 with Salmon Alps for 15 bucks.
I appreciate the offer, though.
Offline Yoe
  • Alps & ISO <3
« Reply #76 on: Sat, 23 May 2015, 04:39:56 »
Cool :) I'd love to see pics of the progress and the finished 60% :D Are you planning to dye some keycaps too?
Offline andCoffee
« Reply #77 on: Sat, 23 May 2015, 18:34:07 »
That's the plan.  I'm currently in the middle of a different project with a Zenith Z-120 board, though, that I want to finish up before diving into this one.
I'll be sure to post pictures when I finish.
Offline Venatorious
  • Gotta Start Somewhere
« Reply #78 on: Sat, 23 May 2015, 18:48:15 »
Whoa when I sold those brown alps I thought you were making just one apple board...
The case you did for the other board is superb.  I can't believe how nice it looks.  I have a lot of apple boards that won't sell but you sure know how to use them.
Keep up the good work, the only alps I use is on a numpad beside my SSK
