Author Topic: Looking for mechanical keyboard where the f keys and number keys line up exactly  (Read 5343 times)
Offline thebloody9
Please suggest a mechanical keyboard where the f keys and number keys line up exactly and there is no space between them.
« Last Edit: Thu, 12 March 2015, 15:16:09 by thebloody9 »
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
I'm not sure exactly what you mean. Are you referring to an Ortholinear keyboard (column layout)? If so, check out http://ortholinearkeyboards.com/.
Offline thebloody9
I mean a keyboard like the keycool 84 or noppoo choc mini, where the number and f keys are perfectly aligned. Are those my only choices for those type of keyboard?
Offline inanis
    • SEALWoodworking
Ah, I see. Yeah, this is not a layout I'm overly familiar with, but those are the two I know of. I'm sure there is a custom that matches this layout somewhere. Perhaps someone more familiar with the 84 key layout can chime in.
EDIT: There is this --> https://geekhack.org/index.php?topic=69064.0
« Last Edit: Thu, 12 March 2015, 15:32:19 by inanis »
Offline thebloody9
Do you need to build customs yourself? Id rather find a prebuilt if possible.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
I think 75% layout is about your best option.  Not much in that form factor though.
Offline thebloody9
So noppo choc mini and keycool 84 are my only options? Which one is better and where can I find them?
