Author Topic: Kinesis Advantage Macro: 9 for triggering Shift-9 ?  (Read 1326 times)
Offline allthumbs
« on: Thu, 12 March 2015, 16:40:59 »
I don't have a Kinesis Advantage (yet?) ... I know you cannot remap 9 to be Shift-9 .... I'm wondering what would happen if you defined a macro to be triggered by a single keypess of 9 where the definition is to press Shift-9
Would that produce (
Or would there be a nasty loop?
You could still produce a 9 with the embedded numpad, right?
I guess my fundamental question is: when you're defining the body of the macro (and when it's playing back a macro) is every keystroke interpreted as that key's native non-customized QWERTY keycode?
Offline allthumbs
Re: Kinesis Advantage Macro: 9 for triggering Shift-9 ?
« Reply #1 on: Tue, 17 March 2015, 13:29:44 »
tech support says yes, (
