Author Topic: My first bolt mod  (Read 2272 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
My first bolt mod
« on: Thu, 12 March 2015, 19:45:24 »
So I got this mystery, unlabelled Model M from the uni that I posted about a while ago, and opened it up. It's from 1987 apparently - same year as me! As many as 17 of the rivets had snapped off - quite a lot. Figured it could do with a bolt mod as I wanted to see if I could improve it. It was INCREDIBLY filthy when I got it:
The key stickers on it were unsalvageable (and annoying anyway) so I peeled them off and cleaned the hell out of everything. I don't have a drill so I had the guys from the mechanical workshop from my uni drill the holes in the barrel plate for me as a favour - they're highly skilled craftsmen equipped with great tools and had the job done beautifully for me - thanks Robert! They also provided the nuts, bolts and washers - I used two different lengths depending on where in the keyboard the bolt came out (I used shorter bolts where they might clash with the top cover or the stabiliser bars on the numpad). And tadaa!
barrel plat with hammers and holes drilled out
the steel plate with bolts
nearly there...
Finished!
Keyfeel and sound has improved noticeably, all keys work and and the keyboard looks virtually brand-new. Hope you guys liked this message :) . Also, many thanks to Azhdar for providing me with the missing ctrl key! :D
« Last Edit: Thu, 12 March 2015, 20:02:04 by chyros »
Offline Altis
Re: My first bolt mod
« Reply #1 on: Thu, 12 March 2015, 20:00:03 »
These things clean up very well. Looks like you've done a good job!
I just got a SSK from '87, my year as well. Enjoy!
Offline 0100010
  • Not Sure
« Reply #2 on: Thu, 12 March 2015, 20:00:20 »
Nice job - it came looking very good.
Offline Bucake
« Reply #3 on: Fri, 13 March 2015, 07:55:27 »
a total beaut
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4 on: Fri, 13 March 2015, 17:15:37 »
Nice restoration!  Looking really good!  Another Model M saved!
« Reply #5 on: Sat, 14 March 2015, 06:08:54 »
Very well done - another M is restored to glory!
Should last at least another 30 years :)
« Reply #6 on: Sat, 14 March 2015, 11:25:15 »
Nice work.
It has never occurred to me to put the screws in from the back.
My original guide by Sandy55 installs them down from the front so I do it that way, too.
I guess that I had assumed that the nuts and protruding screws would interfere with the keys on the downstroke.
- Franklin Roosevelt 1933
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Sat, 14 March 2015, 12:25:48 »
Thanks for the compliments everyone :) .
Nice work.
The don't, fortunately :) . On a few places I used shorter ones because they would clash with the case or stabilisers. I thought it'd be nicer to have the heads on the backside because it looked more elegant and bolts are easier to undo than nuts.
