Author Topic: Duck Lightsaber v2 worklog  (Read 6518 times)
Offline fknraiden
« on: Thu, 12 March 2015, 20:36:11 »
First "expensive" keyboard. Prior boards: Filco MJ1 TKL Browns, Poker II Clears.
Got this from a user in the classifieds and ended up not being what I thought it was. I ended up burning off some diode pads on that pcb with a **** iron,  so I got in touch with the guys over at kbd4u and they shipped me a v2 pcb and a couple blockers I didn't end up using.
Sorry in advance for the potatoes.
Mx Tactile Greys with Spirit 85g springs, some were squeaky so I lightly lubed the springs which seemed to work.
Since I had a v1 plate and pcb originally, I couldn't do the layout I wanted with the plate. So instead of going plateless I took a dremel and just took out the slots preventing me from putting switches/spacebar stabilizer in the location I wanted them to be.
So now everything was ready to be soldered and put together
yay!
thanks for taking the time to get to the bottom.
« Last Edit: Fri, 15 May 2015, 20:58:36 by fknraiden »
Re: Duck Lightsaber v2 worklog
« Reply #1 on: Fri, 13 March 2015, 00:46:32 »
I still need to build mine.  :confused:
Looks great dude!
Offline whentheclouds
« Reply #2 on: Fri, 13 March 2015, 00:51:23 »
two questions:
- did you burn the diode pads by applying the soldering iron for too long?
- 85g greys sound heavy, how comfortable are you on those?
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Fri, 13 March 2015, 02:55:16 »
Do I spot a mx lock on caps lock?
Isn't it "Lighsaver" instead of Lightsaber ?
Azerty Propagandiste
« Reply #4 on: Fri, 13 March 2015, 02:57:20 »
I've seen it called both, my v1 PCB says Lightsaber but I've been calling it a Lightsaver.
Offline fknraiden
« Reply #5 on: Fri, 13 March 2015, 02:57:34 »
Pcb says saber. Either way, I think they changed it from v1 to v2.
Offline fknraiden
« Reply #6 on: Fri, 13 March 2015, 03:03:00 »
two questions:
I'll take some photos later, my previous keyboard had stock clears and they sometimes felt light. I like the very responsive keystroke, dont notice any finger strain.
Offline Ngt
« Reply #7 on: Fri, 13 March 2015, 03:42:09 »
Got this from a user in the classifieds and ended up not being what I thought it was. I ended up burning off some diode pads on that pcb so I got in touch with the guys over at kbd4u and they shipped me a v2 pcb and a couple blockers I didn't end up using.
yay!
Nice build I like it. Damn the dolch set is just so nice. I love it. I wish I was able to get into the group buy ...
Offline fknraiden
« Reply #8 on: Fri, 13 March 2015, 03:47:10 »
yay!
I think zeal might still have some sets. But at this point the hyperfuse looks awesome.
Offline Ngt
« Reply #9 on: Fri, 13 March 2015, 03:53:01 »
yay!
Yeah I know he has some but they are a bit to expensive for me. I jumped in the Hyperfuse anyway. The only thing is that I would have love to have a few more cyan keycaps like in the dolch.
Offline fknraiden
« Reply #10 on: Fri, 13 March 2015, 03:59:07 »
Hyperfuse looks awesome, hopefully you get them soon. I had a old og dolch set and decided to stick with it and get new caps.
Offline ceflame
« Reply #11 on: Fri, 13 March 2015, 04:05:11 »
Nice build log! The keyboard is beautiful.
I'm glad you got the layout you wanted in the end :D
How much of a difference are you finding 85g tactile grays to stock clears? I took a quick look at Sprit's MX spring comparison and it is recorded as "similar" to MX clears.
Offline fknraiden
« Reply #12 on: Fri, 13 March 2015, 04:22:06 »
it starts out a little stronger, but stays consistent throughout. bottoming out is lighter.
« Reply #13 on: Sun, 15 March 2015, 17:41:00 »
please upload the photos when you have the time, i'll be assembling my octagon in the near future and the thought of making similar mistakes make me anxious. really strong fingers btw
