Author Topic: how do I see sent messages  (Read 4458 times)
Offline araif
« on: Fri, 13 March 2015, 16:23:09 »
hello,
how do I see the sent pm messages to other users? https://geekhack.org/index.php?action=pm;f=sent  this page is empty even if I had various conversations with some users..
Offline wlhlm
Re: how do I see sent messages
« Reply #1 on: Fri, 13 March 2015, 16:29:46 »
You have to enable that your messages are saved to your inbox, which can be checked for each PM individually and can be found underneath the text box.
You can also enable this by default under Profile->Acount Settings->Modify Profile->Personal Messaging->"
Save a copy of each personal message in my sent items by default."
« Last Edit: Fri, 13 March 2015, 16:33:00 by wlhlm »
« Reply #2 on: Fri, 13 March 2015, 21:45:46 »
If you select to NOT remember one message that you send, that setting will be remembered and no other messages will be saved until you turn it back on to start saving messages again.
Unfortunately the messages that you have sent are lost.
I believe you can send yourself a message if you want to test the setting.
Offline araif
« Reply #3 on: Sat, 14 March 2015, 14:12:21 »
ok thanks all. that was a bit misleading.
