Author Topic: Wyse without case, starting at $10 + shipping  (Read 2777 times)
« on: Fri, 13 March 2015, 21:41:10 »
It should have a mix of "vintage", old, and new Blacks.  The caps also look like the thick caps to me, but I could be wrong.
http://www.ebay.com/itm/Vintage-1983-WYSE-Keyboard-could-use-for-silver-and-gold-recovery-/191535801018?pt=LH_DefaultDomain_0&hash=item2c986c62ba
Offline Touch_It
Re: Wyse without case, starting at $10 + shipping
« Reply #1 on: Fri, 13 March 2015, 22:54:33 »
Screw vintage blacks and caps,  think about the gold and silver you could recover!
« Reply #2 on: Fri, 13 March 2015, 22:56:31 »
> Spend $200 on materials to recover Ag an Au
> Recover $3 worth of AG and Au
> TFW totally worth it
Offline intelli78
« Reply #3 on: Fri, 13 March 2015, 22:57:12 »
Nice, that does look like the layout that (sometimes? always?) has thick caps. I think it might be more difficult to find a Moogle set than to find thick WYSE, though!
« Reply #4 on: Fri, 13 March 2015, 23:01:58 »
It's not just the layout, but I remember the thick caps also having just a slightly different look to them.   I could be full of ****, but I think I may be right.
Offline intelli78
« Reply #5 on: Fri, 13 March 2015, 23:07:42 »
Well, at least you can mine the keyboard for resources if not  :p
I would be interested if anyone has more info on IDing thick Wyse caps, all I know is that they always seem to be on that layout. I don't know anything about any particular "look" though, or even if that layout is at all a reliable way to ID them.
I used to see a lot more Wyse when I lurked Geekhack in 2013, I think it's fallen out of favor with so many keycap options these days.
« Reply #6 on: Sun, 15 March 2015, 15:05:55 »
I have a case that someone could have if they want to wrap it up and use it
Offline Rotaku
  • Too Based
« Reply #7 on: Sun, 22 March 2015, 16:33:03 »
oh, i actually won this auction last night :D
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
« Reply #8 on: Sun, 22 March 2015, 18:54:51 »
good to hear!
KB is a from a WY-50 and should have the thick keycaps. Don't leave them in the sun or they'll turn yellow.
as far as I know there's not any difference in the legends, but the only stabilized keycap is the spacebar, so that's one way to tell if it has thick or not. I could pull my WYSE keycap box out and check.
I believe this works with soarer's controller code, so you won't even need the cable.
I know, me too.
The WY-50 has thick, the WY-60 has a similar layout but has stabilizers (and fulltouch caps) and thin. The Excellent WY-30 also has thin. AFAIK all versions of the WY-85, PCE and "gate array" have thin but I don't have any to check.
« Last Edit: Sun, 22 March 2015, 18:57:15 by dorkvader »
« Reply #9 on: Sun, 22 March 2015, 19:24:44 »
Thin and thick never seems to have ryhme or reason.  I've had mixed boards and I've had identical boards with different thicknesses.  It's always a gamble.
