Author Topic: Required size for the mount plate to fit in a TEX case  (Read 2195 times)
Offline leandre.north
« on: Sun, 15 March 2015, 02:13:50 »
I am making a mount plate for that is gonna fit in a 60% case what is the measurements I need to fit it in a standard 60% case?
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Required size for the mount plate to fit in a TEX case
« Reply #1 on: Sun, 15 March 2015, 04:59:06 »
« Reply #2 on: Sun, 15 March 2015, 05:00:17 »
Looking for something like this?
https://geekhack.org/index.php?topic=34959.msg954124#msg954124
How will that help me determine the size of my mount plate to make it fit in a TEX case?
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #4 on: Sun, 15 March 2015, 05:09:13 »
Did you try this yet?
http://builder.swillkb.com/
Yes but it gives me a really weird size that is totally wrong when I use my layout. ISO 60% is kind of rare.
Offline Wilba
    • wilba.tech
« Reply #5 on: Sun, 15 March 2015, 05:11:14 »
Post in that thread and swill may help fix the problem.
« Reply #6 on: Sun, 15 March 2015, 05:51:00 »
Thanks, will do.
