Author Topic: The Six Shooter - Teensy adapter PCB for the CM Storm switch tester.  (Read 55195 times)
  • Trade Count: (0)
Re: The Six Shooter - Teensy adapter PCB for the CM Storm switch tester.
« Reply #100 on: Sun, 22 November 2015, 10:38:34 »
I'm literally just starting so buying everything now, so no clipped leads around, and Im not bothering with LEDs so no diodes in my case. 22 guage should be about 0.6m. I'll just give them a shot unless otherwise suggested. it seems to be the most common size carried on small electronic hobby sites (raspi stuff etc).
I've seen the teensy with the pins attached but the headers seemed like it'd be too thick in this case since the teensy seems to need to be mounted petty flush.
Yeah, if you buy the Teensy with pins you'll need to trim them then remove the black spacer to get the height down.  From reading around 22AWG is what's recommended for breadboard so that will work for this - singe core (not stranded) will be easier :)
Offline ShadeDream
  • Trade Count: (0)
« Reply #101 on: Sun, 22 November 2015, 12:18:38 »
Excellent. Yeah I was planning to get the solid core. Thanks!
Offline Spaceman1200
  • Trade Count: (0)
« Reply #102 on: Sun, 06 December 2015, 12:30:36 »
Do you still have any of these? :D
Offline bpiphany
  • Trade Count: (0)
« Reply #103 on: Sun, 06 December 2015, 14:11:36 »
Yes =)
Offline actinium
  • Trade Count: (0)
« Reply #104 on: Thu, 11 February 2016, 21:47:01 »
Are any of these still available?
Offline bpiphany
  • Trade Count: (0)
« Reply #105 on: Fri, 12 February 2016, 02:08:44 »
Well, not at the moment. I thought there wouldn't be much interest any more.. But there is, so I will be ordering more as soon as pcbwing is up and running again after the Chinese New Year. It will be a couple of weeks before I get them. I'll post here to inform you when they are back "in stock".
  • Trade Count: (0)
« Reply #106 on: Fri, 12 February 2016, 11:25:55 »
I imagine everyone here already as a CM Storm switch tester, but if anyone wants an extra case I have one for free, just pay shipping. No switches or caps, just the case. It has a the older logo before they switched from MX Clear to Novatouch Topre; not sure if that makes a difference, but just thought I'd point that out.  :cool:
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • Trade Count: (0)
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #107 on: Fri, 12 February 2016, 11:40:21 »
YGPM!
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
  • Trade Count: (0)
« Reply #108 on: Fri, 12 February 2016, 12:43:50 »
YGPM!
ygpm too!
Offline bpiphany
  • Trade Count: (0)
« Reply #109 on: Tue, 08 March 2016, 13:59:00 »
Got another bunch of PCBs. Anyone still interested send me a PM.
I've also been told there is a new version of the tester itself which has a Topre key like the ones on the novatouch. That case will probably require some more hacking to fit the Six Shooter.
  • Trade Count: (0)
« Reply #110 on: Fri, 11 March 2016, 15:27:55 »
Does anyone use these with my firmware?  I need to know if the new version works.
Offline bpiphany
  • Trade Count: (0)
« Reply #111 on: Sat, 12 March 2016, 03:49:35 »
Is there another? I know grendel made one, but I would just guess most people use yours. It seems very popular with the replacement controllers =)
Offline 00zeRO
  • Trade Count: (0)
« Reply #112 on: Sat, 12 March 2016, 08:13:05 »
Are we talking about easy keymapper?  Cuz it works great for mine...
Offline ShadeDream
  • Trade Count: (0)
« Reply #113 on: Mon, 14 March 2016, 18:04:52 »
I'm using it... was actually browsing this (and it's thread) looking for some answers. It seems to be working well in general, but I'm unable to use alt codes in macros or access the config menu with it. I assume the former is due to the lack of a numlock key on my main board (TKL).
I tried using \NUMLK, at the beginning and end of the macro but it errors during compile saying unrecognized escape sequence.
Setting a config menu key outputs nothing. Im guessing due to the fact that it's not a full keyboard? I wasnt sure if config would work utilizing number and enter keys on my main board or if they had to be on the AVR board. I was looking to enable "unlink num lock" and "virtual num pad" this way to allow for alt codes, but I could be going about this incorrectly.
« Last Edit: Mon, 14 March 2016, 18:06:30 by ShadeDream »
Offline henrikpw
  • Trade Count: (0)
« Reply #114 on: Sat, 13 August 2016, 07:00:19 »
Are you still selling the board?
Offline bpiphany
  • Trade Count: (0)
« Reply #115 on: Sat, 13 August 2016, 16:07:09 »
I still have a ton of them, yes =)
Offline Hax0rc1ph3r
  • Trade Count: (0)
« Reply #116 on: Fri, 13 April 2018, 09:43:13 »
I am hoping that after 2 years that there are still some of these PCBs available! :D
Offline Hax0rc1ph3r
  • Trade Count: (0)
« Reply #117 on: Fri, 13 April 2018, 10:38:51 »
Just got mine today!  Looks pretty~
Anyone know how to open the damned CM storm tester?  I broke a screwdriver trying to pry it open and i couldn't fine any screw holes. o3o
I used one of the opening tools that CM included with their replacement top panels(for the QFR). Even then it is super difficult to open it.
Hopefully mine shows up tomorrow. I really want to get my hands on it :P
Those CM openers are awesome, we need a source for those.
In my search for an the CM opener I found these: https://www.ifixit.com/Store/Tools/iFixit-Opening-Tool/IF145-335-1 I am know sure if they are anything like the CM openers as I have not been able to find a picture of them. I am hoping that this is a tool that will work for the purposes of the community.
Offline ShadeDream
  • Trade Count: (0)
« Reply #118 on: Fri, 13 April 2018, 17:33:50 »
I have a tool kit with these in it and they're far too soft to open the case. I typically use a knife blade personally. My kit even has some metal tools in it but they bend trying to open the tester.
Offline Hax0rc1ph3r
  • Trade Count: (0)
« Reply #119 on: Sat, 14 April 2018, 17:18:48 »
You weren't kidding. I had to use a putty knife that I used to protect the bottom case of the tester, then a small metal pry bar that is used for removing baseboard trim to pull the top from the bottom to get a small flat head screwdriver far enough in to find the catches. There is no way a plastic pry bar would be able to do this. Now I know why they sell them in packs of 5. That's one beefy case for a switch tester.
Offline KTKM
  • Trade Count: (0)
« Reply #120 on: Sat, 16 June 2018, 06:44:14 »
Is this still for sale? How can I buy it?
Offline ShadeDream
  • Trade Count: (0)
« Reply #121 on: Mon, 13 August 2018, 07:09:17 »
Not sure there'll be a lot of interest, but I've made a configuration for this board in QMK. It's available in the main QMK repository now. LED handling is a bit basic but can be customized to do something fancier if you'd like.
Offline 00zeRO
  • Trade Count: (0)
« Reply #122 on: Mon, 13 August 2018, 19:43:42 »
Mechanicalkeyboards.com has one available for sale.
Offline squarefrog
  • Trade Count: (0)
  • \m/_
    • Ergodox Layout Stats
« Reply #123 on: Tue, 30 June 2020, 06:59:55 »
Do you have any of these left still? Shipping to UK from mechanical keyboards is prohibitively expensive :(
