Author Topic: Made a Lego jig for my latest bolt mod  (Read 3623 times)
Offline wholphin
« on: Wed, 18 March 2015, 01:46:51 »
When starting my second bolt mod, I had a look around the house for a cardboard box to cut up for a jig so I don't go bending any of those precious springs. Couldn't find one, so ended up just making one out of  Lego. Possibly not the most original idea, but thought it was a neat way to protect the springs while I work away at removing the plastic rivets.
Apologies for the qualities of the pics, I'm not that good at photography :)
« Last Edit: Wed, 18 March 2015, 03:34:28 by wholphin »
Ducky Shine 3 TKL (Browns) | Ducky Shine 3 Tuhaojin (Browns) | Poker II (Blues) | Model M, bolt modded x2 (03 Jan '90, 18 Jan '90) | Leopold FC660M (Ergo Clears) w/ aluminium case | HHKB Pro 2 | Model M SSK (04 Dec '91) w/ PhosphorGlow's replacement controller | Leopold FC660C | Realforce 104U | Realforce 23UB
Re: Made a Lego jig for my latest bolt mod
« Reply #1 on: Wed, 18 March 2015, 07:29:04 »
Boy, that was a lot of work! I would worry that it would separate if pressed too hard.
I made one for a standard M and one for an F-122 out of scrap 1x2 lumber because I wanted them sturdy.
- D Trump 2026-10-24
Offline wholphin
« Reply #2 on: Wed, 18 March 2015, 13:18:50 »
It's solid enough. I took all the rivets off without it moving or falling apart. It'd probably start falling apart if I took it off my desk, but for its purpose it does the job well.
Those wooden jigs look quite nice - that would be my ideal if I was doing another bolt mod after this one.
« Reply #3 on: Wed, 18 March 2015, 15:42:21 »
Offline wholphin
« Reply #4 on: Wed, 18 March 2015, 15:50:30 »
Ha Ha Ha Ha
I've found Model Ms quite hard to find in New Zealand (well there is an auction for one on Trademe that's been up for ~a month, but they have the starting bid at $320). I may have to do a bit of a visit around some of the computer recyclers. Either way, I've caught the Model M bug :)
« Reply #5 on: Wed, 18 March 2015, 16:06:23 »
Ha Ha Ha Ha
What's shipping like from Australia?  They do turn up from time to time over here, and for considerably less than $320!
« Reply #6 on: Wed, 18 March 2015, 16:27:22 »
Loving that rig!! I have a soft spot for Legos :D
Offline wholphin
« Reply #7 on: Wed, 18 March 2015, 16:28:23 »
Ha Ha Ha Ha
Ah, I should clarify. There's one auction up at current with a starting bid of $320 which was NIB until 2010 (http://www.trademe.co.nz/computers/peripherals/keyboards/corded/auction-859605748.htm). The ones I've managed to get were both for > $90. Might consider shipping from overseas for an SSK though!
« Reply #8 on: Wed, 18 March 2015, 16:58:03 »
The US Post Office has a "large flat rate game board" box that will go to NZ for $77 so if you can crack that nut for shipping the base price might still need to be low.
Model Ms used to sell in the US in the $40-$60 range but recently that has edged up to $60-$80 +
Offline vivalarevolución
« Reply #9 on: Fri, 20 March 2015, 10:30:42 »
Cool jig.
