Author Topic: newegg open box abs m1 $19.99  (Read 5965 times)
Offline wellington1869
« on: Thu, 03 September 2009, 16:03:30 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823224001R
doesnt get much cheaper than that. Shipping is additional $8 for continental US.
on the other hand, for 10 bucks more you can get a new one ($39.99 w/ free shipping, newegg)
« Last Edit: Fri, 04 September 2009, 00:17:55 by wellington1869 »
using: ms 7000/Das 3
Offline jkkhop
« Reply #1 on: Thu, 03 September 2009, 16:24:18 »
Yeah, but how could I get on with a M1 after owning a Filco tenkeyless. There's just no way.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Thu, 03 September 2009, 23:59:57 »
Okay, for anyone who's tried all three:
The Dell AT10xW seems too quiet.
The Focus FK-2001 is my model for what a keyboard should be, as it was my first good keyboard.
Is the M1's sound level closer to the 2001 or the AT10xW?
I listened to Patrick's sound sample, but no context=no clarity.
Already deactivated, BTW.  The $40 one is still there I think.
Overton130, Box Pale Blues.
« Reply #3 on: Fri, 04 September 2009, 00:14:26 »
according to our wiki, the focus fk-2001 is a white alps board. That means it has a built-in click in addition to the botom/topping clacks (and in addition to the tactile bump).
The at101w is a black alps board. It has no click; it only has the topping/bottoming clacks and the tactile bump.
The M1 is also black alps. THough its a slightly different type of alps than found on the at101w, its behaviour will be very close to the at101w (that is: no click, only topping and bottoming clacks, and tactile bump).
So to answer your question, the M1's sound level should be closer to the at101w.  It may have slightly different acoustics but it should be closer to the at101w than the fk-2001.  That said, the topping/bottoming clacks on all of them can get loud even without any built in click.
If you're looking for a quieter alps board you can consider putting the aekII dampened-sliders into any of these boards. THose will greatly reduce the topping/bottoming clacks.
« Last Edit: Fri, 04 September 2009, 00:16:45 by wellington1869 »
Offline Hak Foo
« Reply #4 on: Fri, 04 September 2009, 01:01:01 »
"If you like loud keyboards, the M1 is for you"
"The M1's sound level should be closer to the at101w."
Love the agreement here.
« Reply #5 on: Fri, 04 September 2009, 01:11:44 »
Quote from: Hak Foo;114653
lol.  The at101w isnt exactly quiet... esp if you're a heavy-handed typist. It can clack it up with the rest of them.
From the reviews of the m1 on this site my impression was the m1 was probably slightly louder than the at101w just because of the materials (steel plate, different plastics, different construction of the board).  But its still in the black alps class of switches.
Offline kyamei
« Reply #6 on: Fri, 04 September 2009, 01:15:17 »
The M1 is louder than both the FK-2001 and the AT101W.
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
« Reply #7 on: Fri, 04 September 2009, 01:17:09 »
Quote from: kyamei;114659
it must be one heck of a clacker.
Offline kyamei
« Reply #8 on: Fri, 04 September 2009, 01:59:52 »
It sure is.  That's why I ordered that AEKII.
« Reply #9 on: Fri, 04 September 2009, 02:20:20 »
Quote from: kyamei;114670
kyamei, are you going to use all the sliders from the aekii?  If you're not, i'd be interested in splitting the cost for half the sliders ;)
Also it sounds like both you and me wound up getting mitsumis ;) If thats the case, we could salvage some of our cash and pride by going half-sies.
Thats assuming you dont need all of them though. I only need about 40 damper-sliders, since i'm only doing the swap on the main alphabet cluster.
Offline kyamei
« Reply #10 on: Fri, 04 September 2009, 02:33:30 »
If I like the way it turns out, I'm probably going to rubber damper the entire board.  Plan on using the M1 for games (MMOs) and some of them use F buttons and others use the number pad, so I gotta change em all.
That is of course assuming I don't end up with Mitsumis.
« Reply #11 on: Fri, 04 September 2009, 02:36:40 »
Quote from: kyamei;114674
ya I dont blame you.  If I cant scrounge them up I'll gladly pay for another aekii. Those sliders are the bees knees.
i wish you luck! I was quite surprised when I got mine :(
Offline itlnstln
« Reply #12 on: Fri, 04 September 2009, 07:40:59 »
For a keyboard that not really designed to be loud, the M1 is downright noisy.  Between the clacking and spring sound, it can definitely fill an office with the sound of work.  I would say "industrious chatter,"  but I think "senseless yakking" is more like it.
