Author Topic: PS/2 to USB adapter stuck and lost keys  (Read 6365 times)
Offline Wasder
« on: Fri, 20 March 2015, 11:16:56 »
Hello to all the forum members!
The keyboard model is Compaq MX 11800: http://deskthority.net/wiki/Cherry_G80-11800
The adapter that I'm using is similar to this: http://www.vpi.us/images/usb-ps2-lc.jpg
Generally this setup works fine, except for these problems:
  • Sometimes the pressed key is "stuck", and sent to PC until some key is pressed. Results in something like thisssssssssssssssss.
  • Sometimes the pressed key is not sent to PC at all. Results in something like ths.
  • When playing games which require constantly pressed key (like FPS moving forward), pressing another key may (or may not) "unpress" the pressed key, so it needs to be pressed again.
This is for sure not the keyboard fault, since I've worked with this keyboard for couple of years on a PC with PS/2 ports and never had those issues.
After digging some info on the net, I came up with this article, on which only the last paragraph is interesting:
Why you can't use a third-party PS/2 to USB adaptor:
The I-PAC is a native USB device which auto-detects the interface (USB or PS/2) and invokes a completely different firmware module in the chip accordingly. Some converters are made by companies such as Belkin, which have chips which convert PS/2 into USB. These cannot be used. To understand why, we have to realize that the way in which keystrokes are sent via PS/2 is different to USB. PS/2 protocol sends "Key Down" and "Key Up" commands. In USB, the data sent to the PC is a description of all keys which are pressed at the time. For this reason, the designers of these converters are faced with a problem of potential "stuck keys" in USB, beacuse many PS/2 keyboards intermittently fail to send all of the "key up" commands. A missing "key up" will cause a stuck key in USB which will repeat forever and completely mess up the PC. So what the converters do is cancel all pressed keys from the USB packet every 5 seconds or so, just in case any "key up" commands were missed. So if you are holding the joystick in one direction, the movement will stop after a few seconds.
Also, the USB converters suffer from the same 6-key-pressed limit of standard USB keyboards, whic the I-PAC, in USB mode, does not suffer from.
Source: http://www.ultimarc.com/usb_vs_ps2.html
I guess some more sophisticated converter should be used. Maybe something like those:
http://www.aten-usa.com/products/productItem.php?model_no=UC100KMA#.VQxCQOlsZB1
http://www.clickykeyboard.com/_ebay/modelm_usb/modelm_usb-001.jpg
So my questions are:
  • Is this behavior is known to someone?
  • Which adapter/converter would work for sure without problems?
« Last Edit: Fri, 20 March 2015, 11:21:56 by Wasder »
Re: PS/2 to USB adapter stuck and lost keys
« Reply #1 on: Fri, 20 March 2015, 11:22:18 »
#1 sounds like you've got something shorting out.
#3 sounds like you've only got 2KRO in that board.
« Last Edit: Fri, 20 March 2015, 12:23:42 by CPTBadAss »
Offline Wasder
« Reply #2 on: Fri, 20 March 2015, 12:10:35 »
#2 sounds like you've only got 2KRO in that board.
Hi. I don't think so.
#1 It works OK on the PS/2 port. The problem started only with this USB adapter.
#2
« Reply #3 on: Fri, 20 March 2015, 12:11:55 »
Do you have another adapter you could try? I'm out of guesses.
Offline Wasder
« Reply #4 on: Fri, 20 March 2015, 12:16:01 »
Only like this one, and it doesn't work at all (even no power to LEDs):
The problem is with the adapter. What I want to know is there any adapter/converter that won't have those problems.
Thanks for your help anyway! :)
« Last Edit: Fri, 20 March 2015, 12:18:12 by Wasder »
« Reply #5 on: Fri, 20 March 2015, 12:21:56 »
Oh I like the adapter that Geekhackers.org and Techkeys.us (Run by GHer i3oilermaker!) sells. I've never had any issues with those. Sorry if I misunderstood your question.
Offline Wasder
« Reply #6 on: Fri, 20 March 2015, 12:37:17 »
Looks even more simplistic than one that I have.
Maybe it's for the best :)
Offline aref
« Reply #7 on: Fri, 20 March 2015, 12:57:30 »
I've used this adapter and it works flawlessly, albeit with a Model M. The one you've been using caused me some problems, hence switching to the adapter below. I purchased mine from Amazon.
http://www.amazon.com/Ziotek-PS2-Keyboard-USB-Adapter/dp/B000BSJFJS/ref=sr_1_7?ie=UTF8&qid=1426874900&sr=8-7&keywords=ps+2+to+USB+adapter
« Last Edit: Fri, 20 March 2015, 13:08:46 by aref »
Offline Wasder
« Reply #8 on: Fri, 20 March 2015, 14:48:31 »
I've been looking toward this one too. Thanks for sharing your experience!
Offline aref
« Reply #9 on: Fri, 20 March 2015, 16:19:13 »
My pleasure. Good to know I could help.
