Author Topic: [WTB][US]Cherry PCB Mount Stabilizer Set  (Read 2794 times)
Offline RavenII
  • Trade Count: (0)
« on: Fri, 20 March 2015, 14:41:25 »
Hello all, I was looking to see if any one had a set of PCB mount stabs available. I'd get them from Gon, but that shipping....ugh. Anyhow. Any help/direction is appreciated. Thanks in advance.
Offline RavenII
  • Trade Count: (0)
Re: [WTB][US]Cherry PCB Mount Stabilizer Set
« Reply #1 on: Sat, 21 March 2015, 22:01:20 »
Bump!
  • Trade Count: (0)
« Reply #2 on: Sat, 21 March 2015, 22:08:36 »
What are you calling one set? Like how many keys do you need to stabilize and what size keys?
Offline fknraiden
  • Trade Count: (0)
« Reply #3 on: Sat, 21 March 2015, 22:12:55 »
I'm assuming 1x 6.25 and 6x 2.0
Offline RavenII
  • Trade Count: (0)
« Reply #4 on: Sat, 21 March 2015, 23:45:18 »
Yup, exactly as fknraiden said. Actually it's for a 60% so a 6.25 and 5x 2.0...
Offline sethk_
  • Grand Master Wizard Pizza
  • Trade Count: (0)
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Sun, 22 March 2015, 06:38:22 »
What's the 5th one for? I thought you only needed 1 6.25 and 4 2 for shift, shift, enter, and backspace.
Offline RavenII
  • Trade Count: (0)
« Reply #6 on: Sun, 22 March 2015, 10:46:18 »
Ohhh, right. I keep thinking caps needs it too.
  • Trade Count: (0)
« Reply #7 on: Sun, 22 March 2015, 10:51:43 »
I've got the 2x but not sure about the wire for 6.25x
Offline metafour
  • Trade Count: (0)
« Reply #8 on: Sun, 29 March 2015, 15:06:08 »
I've got a set from one of these keyboards: https://geekhack.org/index.php?topic=69863.0
The 6.25x spacebar stab wire is one of the bent type though. Not sure if that matters.
Offline RavenII
  • Trade Count: (0)
« Reply #9 on: Sun, 29 March 2015, 21:00:20 »
Is there a reason why one wouldn't want to use a bent bar? I'm using a nerd 60 with Gons plate also...
Offline metafour
  • Trade Count: (0)
« Reply #10 on: Sun, 29 March 2015, 22:51:38 »
Looks like using PCB mount stabs with a plate and bent wire causes issues. https://geekhack.org/index.php?topic=60789.330
If you're using them without a plate I'm guessing it will be fine as they came off of a PCB mounted board without a plate.
Offline cmadrid
  • Trade Count: (0)
« Reply #11 on: Sun, 29 March 2015, 23:03:47 »
Might have more luck in a few weeks when the stab GB finishes shipping
Offline RavenII
  • Trade Count: (0)
« Reply #12 on: Mon, 30 March 2015, 10:08:22 »
Ah, yes, that would suck. Thanks anyhow.
I might wait it out. I know IMSTO sells them, but I'm not sure about the quality.
Ever find out if you had the 6.25x wire?
  • Trade Count: (0)
« Reply #13 on: Mon, 30 March 2015, 10:09:24 »
I do not.
