Author Topic: Compatible with Leopold FC200R  (Read 2675 times)
Offline dnLL
« on: Sat, 21 March 2015, 18:06:06 »
http://www.geekkeys.com/white-blank-thick-pbt-108-keyset/
Are these compatible with the 200R? I can't get a reply on the Facebook page or the eBay account so I'm trying my luck here.
Is the spacebar PBT and certified to work well with my Leopold? I know there are some issues with spacebar compatibility with this board.
It's the best price I found for white blank thick PBT in Canada so far.
« Last Edit: Sat, 21 March 2015, 18:07:58 by dnLL »
Offline KnivesM
Re: Compatible with Leopold FC200R
« Reply #1 on: Sat, 21 March 2015, 19:24:31 »
Pretty sure the spacebar is pbt, but the 200R had weird stab placement right? Pretty sure it doesn't come a 2nd spacebar as I have a different set if the same caps.
Edit: http://m.ebay.com/itm/271611781746?_mwBanner=1 not blank but will work with 200R or he has blank navy
« Last Edit: Sat, 21 March 2015, 19:54:12 by KnivesM »
Others
Offline dnLL
« Reply #2 on: Sat, 21 March 2015, 20:18:33 »
Really want blank whites, I'm surprised about how hard it is to find a suitable set.
Actually, my ideal looking board would more be like that but without prints: http://i4.photobucket.com/albums/y146/eddie84/OCN/Mech%20keyboard%20club/key%20caps/Olivetti/DSC09312.jpg
But it's already hard enough to find thick white PBT, I can't find anywhere to order a single red thick pbt keycap or a couple of gray ones.
« Last Edit: Sat, 21 March 2015, 20:28:07 by dnLL »
