Author Topic: Ducky Shine Single Key Issue - Works only when lit.  (Read 1511 times)
Offline toy4x4
« on: Sat, 21 March 2015, 18:51:05 »
The J key only works when lit. It does not work with all backlight levels, only the dimmest and 2 up from there?
All lights off:   does not work
ASDW Lights On: J works
All Lights On - lowest Dim: J Works
All Lights On - Next Level Dim: does not work
All Lights On - Next Level Dim: J Works but inconsistent
So I am wondering if it is going to be resolved by replacing the switch for that key or do I have some sort of other problem in the keyboard?
Offline KHAANNN
Re: Ducky Shine Single Key Issue - Works only when lit.
« Reply #1 on: Sat, 21 March 2015, 19:15:37 »
That doesn't sound like a switch issue, might be a led issue - or a problem with the keyboard
Or just a soldering/contact issue etc, as the J doesn't work when all lights are off
Offline falkentyne
« Reply #2 on: Sat, 21 March 2015, 21:10:04 »
Which ducky shine is this?
1, 2, 3 or 4? Mini YOTS? YOTH? There are TONS of ducky shines...
But sounds like a voltage problem.  I'd RMA it.  This probably isn't user fixable unless you are good with a multimeter and a soldering iron, as it could easily be a solder point, corrosion, a resistor or capacitor at fault here.
A bad switch can't cause this.  Switches either make a contact (completing a circuit) or they don't....
However if you do have spare switches ready and a soldering iron, and you are experienced, there's nothing to lose by trying...
Offline toy4x4
« Reply #3 on: Mon, 23 March 2015, 08:42:48 »
It's a 9008S-B.   Been so long since I bought I I don't remember much else about.
I'll take it apart and check for cold solder joints and trace the voltages.
