Author Topic: KBParadise V60 Arrow Mod Opportunites  (Read 3099 times)
Offline KHAANNN
« on: Sun, 22 March 2015, 00:31:43 »
I have to say I'm very impressed with KBParadise, it seems to me that they obviously think before flooding the market with the first idea they have
I think 60%'s should have arrow keys in the bottom right corner, optimally as 1.25/1.25/1.25+1.75+1, and it seems KBP V60 has an arrow mode that achieves 1.25/1.25/1.25+2.75/balanced - not bad - but not optimal, still pretty good
(i) From the PCB photos here: http://www.hardcoreware.net/kbp-v60-mini-review/ - it seems their PCB also has holes for such a setup, they probably intended for it to be modded as arrow_up+ESC, has anyone explored this option?
(ii) I'm also wondering whether it would be logical to use the right_shift with a side-stem-holdered 1.75 caps-lock keycap, the kind of keycap which they send with keysets, and almost no one uses, so basically it would lean left, and the remaining space would be left empty, I'm not sure whether it would be any better than the normal balanced setup, it would likely rip the switch in the long run, which isn't an issue, yet feeling wise I'm not sure
Offline KHAANNN
Re: KBParadise V60 Arrow Mod Opportunites
« Reply #1 on: Sun, 22 March 2015, 00:52:35 »
Well (ii) is very safe to eliminate
It's a nice way to start appreciating balancers more tho, that side-stemmed keycaps were ... the worst thing I've tried with a keyboard
94811-0
Pressing the corner of the balanced shift keys feels 100x better than the side-stem
Which leaves (i), which I'm guessing can be eliminated, since the plate doesn't have the space/holes with extreme likelyhood
