Author Topic: Ergo Alps Board $50 opening bid or $75 shipped BIN  (Read 1864 times)
« on: Tue, 24 March 2015, 20:07:09 »
It has White Alps.  An interesting board for someone more interesting in history than using it...at least if you feel the way I do about White Alps.
http://www.ebay.com/itm/Vintage-PC-Accessories-102-key-Ergonomical-Machanical-Keyboard-/281640084545?pt=LH_DefaultDomain_0&hash=item41930ea441
Offline 0100010
  • Not Sure
Re: Ergo Alps Board $50 opening bid or $75 shipped BIN
« Reply #1 on: Tue, 24 March 2015, 20:24:04 »
Sent the link to a friend - but that big ass enter.....
Offline Touch_It
« Reply #2 on: Wed, 25 March 2015, 11:06:13 »
big ass enter seems very, uhhh..... un-ergo
Offline orihalcon
« Reply #3 on: Wed, 25 March 2015, 20:06:23 »
I think one of the cooler mods that you can do to this is rewire the left spacebar to be a backspace key or whatever else.  Basically just put a nic in the original traces with a dremel and wire in parallel to the switch that you want it to be the same as.  You can always bridge the nic to restore original function by scraping off the solder mask on both sides and soldering or just wire it up in parallel to the other space bar switch on the other side.
