Author Topic: Filco and Cherry: swapping keycaps?  (Read 1195 times)
Offline spremino
« on: Fri, 04 September 2009, 12:27:09 »
Hello,
can you move home keys' caps on Filco Majestouch and Cherry G80-3000? I'm used to swap J and K and that wasn't possible on rubber dome keyboards I've owned. Model M allows for that.
Thanks
A long space bar... what a waste of space!
Offline timw4mail
    • https://timshomepage.net
« Reply #1 on: Fri, 04 September 2009, 13:37:32 »
Quote from: spremino;114777
Hello,
Thanks
In the same row of the keyboard, you should always be able to swap the keys, and the feel should remain the same.
On most keyboards, each row has a differently contoured key, so switching from different rows can be problematic. On the Model M, the metal backplate is what provides the contour, so all the keys are the same.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline itlnstln
« Reply #2 on: Fri, 04 September 2009, 14:20:57 »
The only you probably wouldn't be able to swap are the non-standard-sized keys like Alt, Ctrl, etc. as stabilizing mechanisms differ slightly from 'board to 'board.  That, and I think Cherry mounts their switches slightly off-center.
