Author Topic: IBM Model F 6110347 NKRO? (Soarer vs xwhatsit)  (Read 2066 times)
Offline antdes457
« on: Wed, 25 March 2015, 20:53:39 »
Hi all,
New here. I have received a 122-key Model F with Soarer's mod from eBay yesterday.
The keyboard works very well and is very good and clean condition. However, I'm noticing problems with simultaneous key presses. While the keyboard seems to register an infinite amount of non-simultaneous key presses, It seems to be limited to 3-4 keys with some key combinations. Is this a limitation from the IBM controller that xwhatsit's controller could fix, is it limited by the keyboard design or am I exceeding some simultaneous keypress buffer in the Soarer controller or USB HID?
I bet someone has the answer but Google and forum search hasn't found an answer so far.
EDIT: Key combinations like 234we won't always register every keys.
« Last Edit: Wed, 25 March 2015, 21:10:56 by antdes457 »
Offline Jotokun
Re: IBM Model F 6110347 NKRO? (Soarer vs xwhatsit)
« Reply #1 on: Wed, 25 March 2015, 21:37:54 »
Interesting. I haven't had any problems in regular use, but trying that 234we combo drops a key occasionally on mine as well.
I'm on Soarers, so I can't offer any insight as to why that happens.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline antdes457
« Reply #2 on: Wed, 25 March 2015, 22:22:21 »
A bit more testing results, it looks like many 5 key clusters won't completely register if they're on multiple row/columns, but I always get a minimum of 3 registered keys.
With Shift pressed, 4+ other simultaneous keypresses will even remove the modifier key.
We'll have to compare with people using tmk_keyboard, xwhatsit's controller on the F, and Soarer on other NKRO keyboards I believe.
Offline antdes457
« Reply #3 on: Thu, 09 April 2015, 22:38:10 »
Moved to a xwhatsit controller and it's fixed now.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #4 on: Thu, 09 April 2015, 23:24:21 »
6 million key rollover? That's impressive.
