Author Topic: Where To Buy Cherry Plate Mount Stabilizers  (Read 2084 times)
Offline nova779
« on: Thu, 26 March 2015, 17:45:16 »
I am nearing completion of my phantom and all I need is a case and stabilizers, I know that GON has PCB mounted but i am in need of plate mount
I am in need of 1 7x and 4 2x
Thanks
Offline feizor
Re: Where To Buy Cherry Plate Mount Stabilizers
« Reply #1 on: Thu, 26 March 2015, 19:36:22 »
If you are in the US you can try mouser? Otherwise Ivan might have some left over from his GB.
Offline feizor
« Reply #2 on: Thu, 26 March 2015, 19:40:57 »
I wish I caught this GB, stabs are so hard to find at a reasonable price. If there are any extras, or if someone overbought, I am very interested in a set and more of possible.
Techkeys will have extras
Actually techkeys are stocking extras, get in touch with boilermaker
« Reply #3 on: Thu, 26 March 2015, 19:41:00 »
The guy who created Planck and Atomic boards has this http://ortholinearkeyboards.com/ site. They're carrying Plate mounted Cherry stabilizers apparently.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4 on: Thu, 26 March 2015, 20:03:38 »
Another place to look, http://www.arrow.com/components/, I don't remember if I looked for 7x but I ordered a bunch of 2x a few months ago.  Just search by Cherry's part number.
Offline nova779
« Reply #5 on: Fri, 27 March 2015, 08:29:40 »
I don't mind buying a wire and replacing it to change the size of the stabilizer if that is at all possible?
Offline Melvang
« Reply #6 on: Fri, 27 March 2015, 09:36:32 »
Thats the only difference between different sizes, the length of the wire.  Cherry wires are a little fussier on location of bends from my understanding and use a larger wire size.
Offline azhdar
  • Praise the AZERTY god
« Reply #7 on: Fri, 27 March 2015, 09:43:05 »
Some stores should really store them alongside with springs, they're pretty annoying to source atm.
Azerty Propagandiste
« Reply #8 on: Fri, 27 March 2015, 09:45:15 »
onlinecomponents.com and Verical seem to have them in stock at the moment. P/N G99-0224 for the 1x2 kit.
Newark, Digi-Key, and Mouser also stock them from time to time.
Offline nova779
« Reply #9 on: Thu, 02 April 2015, 16:26:33 »
I was completely wrong on the sizes that I need, is there any way that I can buy stabilizers and not have to bend my own wires for them, I need  1x2 2x2.25 1x2.75 1x7
Offline Melvang
« Reply #10 on: Fri, 03 April 2015, 11:25:39 »
anything between 1x2 and 1x3 use the same stabs and wire.
