Author Topic: Key Cap Creation (Topre Fn)  (Read 77701 times)
Offline Synjin
Re: Key Cap Creation (Topre Fn)
« Reply #50 on: Sun, 29 March 2015, 21:22:20 »
Mandolin will surprise you :)
Offline daviswalkers
  • HHKB Amature 2
    • Graphic Design Portfolio
« Reply #51 on: Sun, 29 March 2015, 21:23:20 »
Yeah I thought it was him but wasn't sure, he's been on top of things lately so I'm sure.
Compact-SQ |          VE.A
 65g Zealios    |      78g Zealios
Offline Synjin
« Reply #52 on: Sun, 29 March 2015, 21:24:06 »
Yes he has. He has quite a busy schedule but do follow on his progress.
« Reply #53 on: Sun, 29 March 2015, 22:01:30 »
Colored Spacebars! Holy ****... Yes!
Offline ghostjuggernaut
« Reply #54 on: Sun, 29 March 2015, 22:08:16 »
Looking great man. Keep up the pink, I dig it.
Offline Synjin
« Reply #55 on: Sun, 29 March 2015, 22:14:23 »
 I thought the mold was done but it turns out it is OK. It appears that the space bar defect is coming from.my mold and not the resin or injector.
Red ish FN, space bar, and ESC key. I messed them up pretty good because I thought they were done curing but I guess they were still mushy soft. I also ruined them when I was polshishig which was a bad idea since they were mushy to begin with. Edges are weird now on the bottom..
« Last Edit: Sun, 29 March 2015, 22:25:35 by Synjin »
Offline Synjin
« Reply #56 on: Sun, 29 March 2015, 22:26:35 »
There... Finally got the image to work.
Edit:
They snap on and stay on. Here it is on my HHKB with a topre space bar.
I learned tonight that in order to get good results like the first cap I had made, patience must definitely be applied or you will get really bad results.
« Last Edit: Sun, 29 March 2015, 22:49:56 by Synjin »
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #57 on: Mon, 30 March 2015, 00:24:39 »
Any adventurous BS caps soon? :))
Offline dimmu
« Reply #58 on: Mon, 30 March 2015, 00:34:32 »
almost there, bro! keep us updated even with the failed caps, love watching progress posts like these.
« Reply #59 on: Mon, 30 March 2015, 04:51:03 »
Edit:
Oh ****, nice dude! :D  :thumb:
Offline Sed8op8
  • Keyboard Padawan
« Reply #60 on: Mon, 30 March 2015, 05:05:54 »
Edit:
Man this is sweet. Really enjoying the documentation of some of your process. Also space bars  :thumb: whaaaaat . Love it man and good luck .....
« Reply #61 on: Mon, 30 March 2015, 05:14:31 »
I hadn't been following this, but what you have done is extremely impressive!
Well done, sir, very well done indeed! :D
Offline FoC_Tow
  • Brokehlicious
« Reply #62 on: Mon, 30 March 2015, 05:29:20 »
Congratz on the thread Synjin and best of luck!  :thumb:
Also +1 definitely diggin the pink! =)
Offline Synjin
« Reply #63 on: Mon, 30 March 2015, 06:59:24 »
Thanks guys. I'm kind of low on funds due to my recent purchases but once I recover, I will redo the molds since that is the most expensive part of it,until then, the defects will always be quite similar.
Offline heedpantsnow
  • Old enough to know better
« Reply #64 on: Mon, 30 March 2015, 08:44:45 »
Wow man you're making crazy-fast progress!  I'm excited to see that you're already putting out quality stuff (even though I don't use Topre).
I'm back.
Offline Synjin
« Reply #65 on: Mon, 30 March 2015, 08:51:21 »
I can make MX as well but I don't have the materials for the mold currently. I was thinking of making an MX esc wasd combo
Offline FoC_Tow
  • Brokehlicious
« Reply #66 on: Mon, 30 March 2015, 12:23:55 »
Offline hjc1710
« Reply #67 on: Thu, 02 April 2015, 00:30:58 »
http://imgur.com/a/FgqOw
My cast tonight. I was casting in peace carefully loading the resins into the injector when the damn resin started boiling up and curing. It sucks when you ruin your injector because you didn't know that one of the filler compoundsbyou use ends up accelerating cure time from 30 minutes to 2 minutes...
Injector got ruined and I had to rush the process so here are the pics of the partially cured material that was squeezing through.
Holy ****ing **** that teal... Wow... Just wow. That's an amazing colorway.
I have no Thorpie :(. When you make MX, consider me already a customer ;).
Filco Majestouch II (B) | Poker II (BR) | Cherry G80-11900 (BLK) | Das V3 (BR) | RS84 (soon...)
Granite | Skull Squadron | Deep Space | Raindrop R2 | Hyperfuse GMK (soon...)
Offline Synjin
« Reply #68 on: Thu, 02 April 2015, 09:53:49 »
Made some deep purple set. Looks blue due to crappy phone pics and yellow roof lighting.
« Reply #69 on: Thu, 02 April 2015, 14:24:06 »
What's the story with the power text?  That purple looks amazing!
I'm back.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #70 on: Thu, 02 April 2015, 14:51:29 »
I think thats from the HHKB, there is a cap that has Power on the side.
Offline Synjin
« Reply #71 on: Thu, 02 April 2015, 14:53:00 »
Indeed. I tried to get the legends on it bit it is harder
Offline VivaGardner
  • www.gboarding.com
« Reply #72 on: Sat, 04 April 2015, 18:38:25 »
looking good! I only have cherry mx right now though
Even good dogs go wild
« Reply #73 on: Sat, 04 April 2015, 18:40:53 »
Yup.  That's why I didn't make more Topre FNs than I did.  I hated the look of the legend showing up on the FN.  That's changing though.
Offline Synjin
« Reply #74 on: Sat, 04 April 2015, 18:51:08 »
I have made the TORPEEE Fns without the text successfully. I just keep having some issues on flashing but otherwise they look smegma, I meant decent. I will be posting some pics later or tomorrow. Is it best to post Ina reply or by updating the OP?
Offline byker
  • Literally Canada
« Reply #75 on: Sat, 04 April 2015, 18:56:22 »
I think either work. Or you could do both. :) If you do edit the OP, make sure to post so that we know it has been updated!
« Reply #76 on: Sun, 05 April 2015, 14:12:26 »
Awesome dude!
Offline Sed8op8
  • Keyboard Padawan
« Reply #77 on: Sun, 05 April 2015, 14:16:24 »
Ahhhhh no smegma lol I'm sure there is no smegma on the caps or we might have to evaluate how you make these things lol     ;) looking sooo good
« Last Edit: Mon, 06 April 2015, 05:36:43 by Sed8op8 »
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #78 on: Tue, 07 April 2015, 14:14:00 »
Nice work, Synjin! Somehow, I missed this for a while, but it looks like you're making some very interesting stuff.
Hopefully, there will be more to come soon. :)
Offline Synjin
« Reply #79 on: Tue, 07 April 2015, 14:16:50 »
Thanks dude. I've got some better ones now but I still haven't uploaded the images of the ones I made recently. I'm actually trying to make a set that would match one of the clacks I have in the mail but Idk how difficult it would be matching it with someone else's colors especially if I am basing it off a photo and not irl true color representation.
« Reply #80 on: Tue, 07 April 2015, 14:26:49 »
Oh cool, clacks in the mail is music to the ears.  Although, clacks on the doorstep is even better. I think I read yesterday you saying you had an OG on the way?
EDIT: If so, you'll have to update your signature. "Eventually I shall obtain an OG Clack"
Let me know when you start selling some of your homebrew creations, I'll definitely toss some bones your way to support you.  :thumb:
« Last Edit: Tue, 07 April 2015, 14:28:59 by cooldiscretion »
Offline Synjin
« Reply #81 on: Tue, 07 April 2015, 14:30:29 »
I'll let you know for sure. This arrived yesterday but there is another one coming.
« Reply #82 on: Tue, 07 April 2015, 14:32:19 »
Wowzers. Very nice.
Offline Synjin
« Reply #83 on: Tue, 07 April 2015, 16:02:14 »
Here are some of what I've made so far. Progress is slow since I am waiting for my materials to arrive and can't really do anything until then. Some of them are a bit wonky because I removed them when they were soft. F2 clack is courtesy of the guy who sold me my ruby red :)
« Reply #84 on: Tue, 07 April 2015, 16:06:56 »
Amazing work Synjin. You are making some really fast progress. Can't wait to see where this goes.
Offline Synjin
« Reply #85 on: Tue, 07 April 2015, 16:08:06 »
Those greens are all the same color which is dark green inspired by one of my incoming items. The lighting makes it look different but its because he light shines on the FNs differently.
Offline Sed8op8
  • Keyboard Padawan
« Reply #86 on: Tue, 07 April 2015, 16:11:48 »
dam you have been busy stacking caps  :eek:
Very sexy syn
Offline Synjin
« Reply #87 on: Tue, 07 April 2015, 16:12:32 »
Hehe. Thought I'd show some since my type s just arrived today
Offline FoC_Tow
  • Brokehlicious
« Reply #88 on: Tue, 07 April 2015, 16:13:30 »
Looking great Sir!
The quality, especially of the green and blue ones looks amazing!  :thumb:
That profile mixing tho... xD
Offline Synjin
« Reply #89 on: Tue, 07 April 2015, 16:14:34 »
Haha. I only have so many places to put the FNs. Do you guys think these wold be of decent quality to have a sale in the future?
« Reply #90 on: Tue, 07 April 2015, 16:36:46 »
Wow, some great work so far man! Stoked to see more Topre colors! :D Orange and Purple hopefully!
Nice OG too!  :thumb:
Offline Synjin
« Reply #91 on: Tue, 07 April 2015, 16:37:41 »
Thanks. I'll be making some orange soon.
Offline FoC_Tow
  • Brokehlicious
« Reply #92 on: Tue, 07 April 2015, 16:42:43 »
Congratz on your Type S man!  :)
Yesh pls Synjin!
The quality looks amazing on the latest pics except for very few random surface spots here and there! :)
Would be awesome if you could do stuff like arrow key sets, or since your already doing space bars, maybe control keys or Shift plus FN set.
Shift plus Fn would make for a full modifier row for example...  :thumb:
Also the FNs are shift row profile tho I guess, so you could use them as blanks on the lowest alpha row, right? xD
Offline Synjin
« Reply #93 on: Tue, 07 April 2015, 16:44:04 »
Yeah. I will do more but I don't have enough materials right now.
Offline btctopre
« Reply #94 on: Tue, 07 April 2015, 17:29:05 »
Yep. Your caps are looking great so you should have no problem selling out  :thumb:
Offline Synjin
« Reply #95 on: Tue, 07 April 2015, 17:33:28 »
You think there would be enough interest if I was to do a giveaway?
« Reply #96 on: Tue, 07 April 2015, 17:38:30 »
Definitely. Getting your caps out so people can comment on the quality is probably the best way to increase interest/ build hype for a sale.
Offline Synjin
« Reply #97 on: Tue, 07 April 2015, 17:44:42 »
I wanted to do a giveaway but thought of maybe having the winners do an honest review if the cap they get.
« Reply #98 on: Tue, 07 April 2015, 17:54:00 »
« Reply #99 on: Tue, 07 April 2015, 17:58:32 »
I know other makers have asked owners to point out any flaws with caps so they can improve future casts.
