Author Topic: Thanks GeekHack  (Read 2422 times)
Offline Ardvan
  • Keep it simple, stupid
Thanks GeekHack
« on: Sun, 29 March 2015, 05:40:19 »
Hi
After lurking for two weeks I finally registered. I found my love for tinkering with hardware again. :)
I still can't typ 100% blind, because I work with Windows at the office and most of the time PuTTY with UNIX/tmux/vi, have a Mac at home and play games on a PC. I have to rotate between ASCII and German-Layouts for Mac and/or PC and it's driving me crazy.
For quite some time I had to work with those cheap light Logitec keythingys because I didn't want to transport a heavy keyboard with me. Additionally I have installed all those software tools that allow you to change key maps and settings and stuff on a Mac and Window, but they often do not do what I wanted and it is not consistent over different operating systems.
All those years I dreamt of keyboards (or modify my HHKs) that just do what I think they should do and can't be controlled by silly computers
Why are todays keyboards still so 1920s? I mean it's a device many people need to interact with computers daily, for hours.
Now I found your awesome forum. You people have basically already done all the stuff years ago, I still thought didn't exist.
So what did I do the last two weeks?
I cleaned my HHK's after 10 years for the first time. They are now clean and shiny again, have o-rings in them to damped the release sound. And I bought blind keycaps to force me to typ without cheating.
But most importantly I am adding now a new controller. :D
So I have to go back drilling holes into my HHK's.
No worries! I love my HHKs  and will keep them until I die, so no need to do reversible mods.
HHK HHK
Offline Dihedral
  • Mostly Harmless
Re: Thanks GeekHack
« Reply #1 on: Sun, 29 March 2015, 08:24:09 »
Nice board! Good luck with your controller mod.
Offline Ardvan
Re: Thanks GeekHack
« Reply #2 on: Mon, 30 March 2015, 01:34:19 »
In fact, I am writing this here the first time with my modified HHK with a teensy++ inside and the tmk_keyboard software. :)
HHK HHK
Offline Lain1911
  • God of the Wired
Re: Thanks GeekHack
« Reply #3 on: Mon, 30 March 2015, 01:36:36 »
10 year HHBK? :o Nice, also I hope that more than one thing from the 1920's come back  :thumb:
Re: Thanks GeekHack
« Reply #4 on: Mon, 30 March 2015, 05:05:02 »
Welcome to Geekhack!
German layout is QWERTZ, isn't it?  That would be awkward switching back and forth :eek:
If you have been using an HHKB for a while, at least you would be used to the arrow keys and function keys, so otaku keycaps will just help you to touch type better :)
There is also talk of an aluminium case for the HHKB.  Coincidentally two groups seem to be planning one at the same time.  Something else to enhance your oneness with cup rubber :D
Offline Ardvan
Re: Thanks GeekHack
« Reply #5 on: Mon, 30 March 2015, 10:49:41 »
Yes, I got used to the arrow keys and volume up/down and power switch for the mac.
Here we have Swiss-German keyboards. They are nice if you want to write German, French and Italian at the same time, but not efficient for coding. But I need all the /, |, \ and brackets {},[],() as well the @ and ~ and backtick `. And they are not on the same places between Mac and PC. The Y and Z swap isn't so much of a problem.
Well I need now a few weeks to tune the tmk-software until it feels right.
Aluminium Case for sure is nice (preferably with deep blue or violett eloxation) but at the moment I don't think I want to redo this ;D
HHK HHK
Re: Thanks GeekHack
« Reply #6 on: Tue, 31 March 2015, 04:57:12 »
Whoa!  That looks very neatly done!
Three USB port hub?  Nice :)  I haven't found anything that works in the standard USB ports on my HHKB, not even a USB memory stick.
Offline pr0ximity
Re: Thanks GeekHack
« Reply #7 on: Tue, 31 March 2015, 18:58:02 »
Cool board! I've never typed on a HHKB but I can definitely see the appeal  :thumb:
Offline Ardvan
Re: Thanks GeekHack
« Reply #8 on: Wed, 01 April 2015, 06:57:16 »
Thanks for your kind words!
I did that USB-hub only once. It was a real pain to do.
And the cable soldering to the LED bar could be better. But hey it works!
Here the first power up with the blinky software :D
And from behind.
HHK HHK
Offline Hoaryhag
Re: Thanks GeekHack
« Reply #9 on: Wed, 01 April 2015, 14:36:26 »
Very slick board. :cool:
