Author Topic: Alternate hosts for imgur - specifically embedded.  (Read 2722 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« on: Sun, 29 March 2015, 12:01:12 »
So work block imgur (surprise) so all these amazing picture on here I can't view until I get home. I have an extention plugged into chrome which someone has sent me. It's mainly for opening imgur links from Reddit, but I was hoping someone would be able to help me with something where I could see embedded imgur pictures but not through imgur.
I've tried just opening them in a new tab from the picture, and it doesn't work. Here is the script if anyone is interested.
Code: [Select]
// ==UserScript==
// @name           Imgur.com/filmot.com to kageurufu.net converter
// @namespace      reddit
// @description    Changes imgur.com/filmot.com links to kageurufu.net
// @include        http://reddit.com/*
// @include        http://www.reddit.com/*
// ==/UserScript==
var anchors = document.getElementsByTagName('a');
for (var i = 0; i < anchors.length; ++i) {
    var a = anchors[i];
    if (a.href && a.href.indexOf('http://imgur.com/') == 0) {
        a.href = a.href.replace('http://imgur.com/', 'http://kageurufu.net/imgur/?');
        a.href = a.href + '.jpg';
    if (a.href && a.href.indexOf('http://filmot.com/') == 0) {
        a.href = a.href.replace('http://filmot.com/', 'http://kageurufu.net/imgur/?');
    if (a.href && a.href.indexOf('http://i.imgur.com/') == 0) {
        a.href = a.href.replace('http://i.imgur.com/', 'http://kageurufu.net/imgur/?');
    if (a.href && a.href.indexOf('http://i.filmot.com/') == 0) {
        a.href = a.href.replace('http://i.filmot.com/', 'http://kageurufu.net/imgur/?');
    if (a.href && a.href.indexOf('http://www.imgur.com/') == 0) {
        a.href = a.href.replace('http://www.imgur.com/', 'http://kageurufu.net/imgur/?');
var imgs = document.getElementsByTagName('img');
for (var i = 0; i < imgs.length; ++i) {
    var img = imgs[i];
    if (img.src && img.src.indexOf('http://imgur.com/') == 0) {
        img.src = img.src.replace('http://imgur.com/', 'http://kageurufu.net/imgur/?');
        img.src = img.src + '.jpg';
    if (img.src && img.src.indexOf('http://filmot.com/') == 0) {
        img.src = img.src.replace('http://filmot.com/', 'http://kageurufu.net/imgur/?');
    if (img.src && img.src.indexOf('http://i.imgur.com/') == 0) {
        img.src = img.src.replace('http://i.imgur.com/', 'http://kageurufu.net/imgur/?');
    if (img.src && img.src.indexOf('http://i.filmot.com/') == 0) {
        img.src = img.src.replace('http://i.filmot.com/', 'http://kageurufu.net/imgur/?');
    if (img.src && img.src.indexOf('http://www.imgur.com/') == 0) {
        img.src = img.src.replace('http://www.imgur.com/', 'http://kageurufu.net/imgur/?');
I tried adding geekhack to the "include" list but it didn't work. Probably did it wrong as I have no idea what I'm doing.
Edit: no idea how to make that box bigger =/
Offline Dihedral
  • Mostly Harmless
Re: Alternate hosts for imgur - specifically embedded.
« Reply #1 on: Sun, 29 March 2015, 12:08:09 »
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
I manually use filmot by just replacing the i.imgur in the url with filmot.
i.imgur.com/m3da5.png
filmot.com/m3da5.png
Offline trizkut
« Reply #2 on: Sun, 29 March 2015, 12:23:09 »
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
Can you show the modifications you tried on the source script?  Would make things easier  ;D
Offline katushkin
  • Just the guy
« Reply #3 on: Sun, 29 March 2015, 12:39:53 »
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
Does that work with embedded links too?
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
The top bit was the only bit I added, all I put was:
// ==UserScript==
// @include        http://geekhack.org/*
// ==/UserScript==
That's it. So it's probably completely wrong hah :)
Offline Dihedral
  • Mostly Harmless
« Reply #4 on: Sun, 29 March 2015, 12:41:50 »
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
Code: [Select]
// ==UserScript==
// ==/UserScript==
    var a = anchors[i];
    var img = imgs[i];
// ==UserScript==
// @include        https://geekhack.org/*
// ==/UserScript==
I think you're going to want to just copy url and paste it and change to filmot each time. Painful, but it will work.
