Author Topic: Nothing in Sent Items  (Read 14057 times)
Offline Dark_wizzie
« on: Tue, 31 March 2015, 04:49:11 »
Hi,
I PM'ed somebody but it doesn't show up under Sent Items. I'm afraid my message never got through. When I clicked 'send', it says the message was sent successfully, so I'm a bit confused.
Thanks.
Beep Boop
Re: Nothing in Sent Items
« Reply #1 on: Tue, 31 March 2015, 04:52:15 »
Just under where you type the message is a checkbox "Save a copy in my outbox - is it checked?
If not, a copy will not be saved.
And if you happen to UNcheck it, it will remain unchecked for all subsequent PMs until you deliberately check it again.
Offline Dark_wizzie
« Reply #2 on: Tue, 31 March 2015, 04:56:56 »
Ahh, thank you. I thought such an option would be checked by default. Other forums I've been to show a copy of sent posts by default.
Beep Boop
« Reply #3 on: Tue, 31 March 2015, 05:04:18 »
I'm also given to understand that you can send a PM to yourself if you want to test it.
Talking to yourself via PM :))
Offline aznairjordan
« Reply #4 on: Wed, 06 May 2015, 13:13:19 »
Hi,
Thanks.
You can also check the "Save a copy of each personal message in my sent items by default." box under Personal Messaging in your Acc Settings >> Modify Profile >> Personal Messaging
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline Acerk
  • I pay attention to details!
« Reply #5 on: Fri, 19 June 2015, 14:07:10 »
I wish this was a default feature, and people instead removed things from their sent category. Similar to an inbox. I always forget to check this box before sending.
Thanks for the settings advice ;)
Offline wlhlm
« Reply #6 on: Fri, 19 June 2015, 14:14:55 »
Have to agree with you. Makes no sense to me why it isn't the default setting.
« Reply #7 on: Sat, 20 June 2015, 03:38:57 »
Once you set it, it should stay checked for all subsequent PMs (until you uncheck it again).
Offline Philister
« Reply #8 on: Sat, 29 April 2017, 14:51:20 »
Sorry for being a clueless Necro, but I can't figure out how to get to my outbox / sent items list for personal messages (yes, I have ticked the box to save them). Thanks!
Offline xondat
  • i'm not a star
« Reply #9 on: Sat, 29 April 2017, 14:54:58 »
Offline Philister
« Reply #10 on: Sun, 30 April 2017, 02:49:47 »
Got it. Many thanks!
