Author Topic: Infinity ErgoDox (Infinity X ErgoDox by Massdrop)  (Read 15113 times)
Offline davkol
  •  Post Editing Timeout
« on: Tue, 31 March 2015, 06:26:41 »
It seems Massdrop is replacing the ordinary ErgoDox in their semi-regular drops. The new design has the same physical layout, but hardware is more like their Infinity 60% keyboard. Links:
Features:
  • much better connection between halves, no more messing with TRRS cables/connectors or flipping halves for only left-handed use
  • support for both MX-compatible and Alps SKCM-compatible switches
  • everything but switches comes presoldered
  • runs HaaTa's firmware, configuration is done in the KLL or future matt3o's GUI
  • a gimmicky LCD
The drop features a choice of Cherry MX, Gateron and Matias switches, and DSA and DCS keycaps for MX-compatible or DSA keycaps for Matias/Alps switches. Price remains essentially the same.
Still no tenting support out of the box, the same layout, no backlighting but an LCD instead. I'm not sure how I feel about it.
I'm curious how the new interconnection works. I hope there's a controller in either half.
Re: Infinity ErgoDox (Infinity X ErgoDox by Massdrop)
« Reply #1 on: Tue, 31 March 2015, 07:31:24 »
Offline daerid
    • Rossipedia
« Reply #2 on: Thu, 02 April 2015, 01:48:23 »
Apparently the PCB supports backlighting, it just doesn't come with any LEDs
Offline Input Nirvana
« Reply #3 on: Sun, 05 April 2015, 17:39:50 »
Improved design, better pricing, the Input Club engineered a great product and addressed many requests.
Keep in mind this is merely a stepping stone to even better in the future.
Offline ideus
  • Björkö.
« Reply #4 on: Sun, 05 April 2015, 17:41:33 »
If the PCB actually supports back-lighting it requires the places for the resistors to be soldered.
Offline Parak
« Reply #5 on: Sun, 05 April 2015, 17:43:52 »
There's only a need for a single resistor, on the LED driver, which is used by the whole matrix.
Offline ideus
  • Björkö.
« Reply #6 on: Sun, 05 April 2015, 17:48:46 »
Interesting, could that be done with for example the Nerd60? Or why this last requires resistors per switch? Or the term "back-lighting" here does not refer to the LEDs installed at each switch?
Offline Parak
« Reply #7 on: Sun, 05 April 2015, 19:47:24 »
It's a normal function of the LED driver. Using a single resistor requires using such a driver, or a similar one, so it would not apply to anything that does not use such a driver.
Offline Heliobb
« Reply #8 on: Sat, 30 May 2015, 05:51:05 »
Thanks for the info. 4,039 users have requested this product, impressive.
Novatouch TKL - Leopold FC660C - PBT my life.
