Author Topic: Learning Python  (Read 8578 times)
  • Live long and prosper
Learning Python
« on: Wed, 01 April 2015, 10:50:59 »
So I've been using Codeacademy to try and learn some Python stuff, and I get to this lesson when it says to:
Instructions
Create three dictionaries: lloyd, alice, and tyler.
Give each dictionary the keys "name", "homework", "quizzes", and "tests".
Have the "name" key be the name of the student (that is, lloyd's name should be "Lloyd") and the other keys should be an empty list. (We'll fill in these lists soon!)
And this is my code:
Code: [Select]
lloyd = {
    'name': ['Lloyd'],
    'homework': [],
    'quizzes': [],
    'tests': []
alice = {
    'name': ['Alice'],
    'homework': [],
    'quizzes': [],
    'tests': []
tyler = {
    'name': ['Tyler'],
    'homework': [],
    'quizzes': [],
    'tests': []
And it keeps giving me this error:
Oops, try again. The name key does not have the value "Lloyd" in your lloyd dictionary.
Am I crazy, or is Codeacademy crazy?
tp thread is tp thread
Re: Learning Python
« Reply #1 on: Wed, 01 April 2015, 10:55:39 »
Do they want "Lloyd" including quotes?
Re: Learning Python
« Reply #2 on: Wed, 01 April 2015, 10:58:47 »
single and double quotes are interchangeable in Python as far as I know. and I tried both and got the same error.
Offline trizkut
Re: Learning Python
« Reply #3 on: Wed, 01 April 2015, 11:06:57 »
get rid of the square brackets surrounding the names, I don't think they want a list for the name key.
Offline Dihedral
  • Mostly Harmless
Re: Learning Python
« Reply #4 on: Wed, 01 April 2015, 11:08:14 »
Code: [Select]
lloyd = {
    'name': 'Lloyd',
    'homework': [],
    'quizzes': [],
    'tests': []
alice = {
    'name': 'Alice',
    'homework': [],
    'quizzes': [],
    'tests': []
tyler = {
    'name': 'Tyler',
    'homework': [],
    'quizzes': [],
    'tests': []
Re: Learning Python
« Reply #5 on: Wed, 01 April 2015, 11:13:12 »
welp... problem exists between keyboard and chair...
Offline Dihedral
  • Mostly Harmless
Re: Learning Python
« Reply #6 on: Wed, 01 April 2015, 11:14:32 »
It's a reasonable mistake to make. The lesson or whatever it's called was not too explicit in its' requirements.
Re: Learning Python
« Reply #7 on: Wed, 01 April 2015, 17:22:43 »
I am getting PTSD from 'learning' this in school. What an absolute nightmare of a language.
Offline clacktalk
  • circa 2015
Re: Learning Python
« Reply #8 on: Wed, 01 April 2015, 17:24:14 »
what
diary of a clacktalk
radio_killah: too much frank
Offline exitfire401
  • The Force is Re/\l
Re: Learning Python
« Reply #9 on: Wed, 01 April 2015, 17:28:43 »
Looks like you got one of them I d10 T errors sir. Take two of these, and call me in the morning.
But really, it happens. Took me a long time to learn how to look for errors in Python. Simple mistakes happen. As long as you're learning from them, it's completely acceptable.
Offline pr0ximity
Re: Learning Python
« Reply #10 on: Wed, 01 April 2015, 21:27:18 »
What do you prefer? Or perhaps I should say, what makes it a 'nightmare'?
Offline jacobolus
Re: Learning Python
« Reply #11 on: Wed, 01 April 2015, 21:32:45 »
I assume this is an April Fools joke?
Offline retrochick
  • goodbye my wallet
Re: Learning Python
« Reply #12 on: Mon, 20 April 2015, 11:13:43 »
I've found Code Academy to be a great intro to coding for people who have no experience whatsoever, but soon you will realize that you want to go more in depth with a language than just printing out strings and numbers. Also as mentioned above, the instructions are sometimes not very clear and Code Academy tends to move rather slowly. If you have some experience in programming, http://help.exercism.io/getting-started-with-python.html might be more helpful. You basically use Git to commit and push your changes/exercises, which is then peer reviewed. The feedback is actually helpful, and they suggest ways to help you improve your code. Another good resource to check out if you're somewhat of a beginner but you're familiar with terminal and coding in general would be Learn Python The Hard Way by Zed Shaw.
