Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
Source for Replacement XT Model F Feet
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Source for Replacement XT Model F Feet (Read 2126 times)
Great Hierophant
Thread Starter
on:
Mon, 07 September 2009, 00:57:20 »
I have an 83-key XT Model F in good shape. These keyboards have four circular pads underneath them with a diameter just greater than a quarter. Unfortunately, time has worn away the adhesive and all have fallen off. You can see what they look like here:
http://www.clickykeyboards.com/index.cfm/fa/categories.main/parentcat/11066
Anyone know where I can get replacements from? If I can find replacements, what kind of adhesive should I use to get them to stick the metal back of the keyboard?
Logged
InSanCen
Reply #1 on:
Mon, 07 September 2009, 01:19:10 »
Most electronic retailers will probably carry something you can cut to size.
If you're US based, then DigiKey, Mouser, McMaster-Carr are likely suspects.
If you're UK Based, then Maplin Electronics, Farenll, RS Components.
Last Edit: Mon, 07 September 2009, 01:31:51 by InSanCen
Logged
Currently Using :-
IBM M13
1996, Black
Currently Own :-
1391406
1989 & 1990
AT Model F
1985
Boscom 122 (Black)
G80-3000
G80-1800 (x2)
Wang 724
G81-8000LPBGB (Card Reader, MY)
Unitek
AT102W
TVS Gold
Project's :-
122 key 1389620 Wireless ESP32
'Pooter :-
Xeon E5-2680v4
Machinist MR9A
2x16GB DDR4
Radeon RX6600
NVME & Spinning rust
clickclack
Maker
Board Chow EXTRAORDINAIRE
Reply #2 on:
Mon, 07 September 2009, 02:25:56 »
It might be most effective (if you want the original look) to just get thin cork board and get some double sided tape. And cut the cork to the desired size/shape and adhere.
You can get all of the above at a craft store or even a hardware store.
If however you just want some sort of non slip pad, just go to an electronic store, craft store, hardware store and pick something similar out(non slip rubber feet/pads). It shouldnt matter what you use, unless you want that authentic look.
And last but not least If for some reason those options don't seem like a good fit for you, then I might have another option.
good luck
Logged
862+ keyboards and counting!
R.I.P.ster
Vendor link ->
Clack Factory
itlnstln
Reply #3 on:
Tue, 08 September 2009, 09:42:04 »
Use some shelf liner (the rubbery-grippy kind). That keyboard won't be going anywhere.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
