Author Topic: .  (Read 2347 times)
Offline alienman82
« on: Thu, 02 April 2015, 13:43:13 »
removed.
« Last Edit: Thu, 01 March 2018, 17:32:53 by alienman82 »
Re: 2 Mx Clear g80-8113's on Ebay
« Reply #1 on: Thu, 02 April 2015, 13:59:00 »
There are two listings on Ebay for g80-8113 keyboards with mx clears.  The buy it now option has no pictures of the switches, but I asked him what color they are and he said "white."  My guess is mx clears since cherrycorp describes these boards as having mx switches.  Buy it now price is $48 and the auction is currently at $42.
http://www.ebay.com/itm/231503884780?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/221728261156?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://cherrycorp.com/product/8113-series-msr-keyboard-with-touchpad/
Not a bad deal if someone wanted to use these as-is. If you are buying to harvest switches, you'd be better off just buying new clears. The one with BIN could be MX browns or clears, no way of knowing.
Offline alienman82
« Reply #2 on: Thu, 02 April 2015, 14:01:16 »
removed.
« Last Edit: Thu, 01 March 2018, 17:32:52 by alienman82 »
« Reply #3 on: Thu, 02 April 2015, 14:26:16 »
Maybe I wasn't clear.  I asked him to remove a keycap and tell me the color of the switches to which he responded "white."  My guess is clear switches.
Ah, okay. Yeah, they would be clears then.
