Author Topic: adapter for RJ11 wyse keyboard  (Read 5427 times)
Offline magicwuff
« on: Thu, 02 April 2015, 21:29:13 »
Hello GeekHackers!
I recently saved this beauty from the landfill and have cleaned it up:
http://ineedtoarduiknow.tumblr.com/post/115350355850
I am told the "Reynolds + Reynolds" logo refers to a software that the keyboard went with at the time.
After doing some research here and elsewhere, I have determined that the RJ11 connector can either be compatible with PS/2 (clock, data, +5 and ground), or not (TX, RX, +5 and Ground). Does that sound right?
Should I snip the end off and connect to a PS/2 connector, or is there more involved? I have an arduino if needed for testing.
Re: adapter for RJ11 wyse keyboard
« Reply #1 on: Thu, 02 April 2015, 21:58:46 »
Soarer made a wyse converter, have you seen that?
Offline magicwuff
« Reply #4 on: Fri, 03 April 2015, 20:37:46 »
I don't think this is the exact adapter that you want, but they are out there:
http://www.ebay.com.au/itm/WYSE-KEYBOARD-ADAPTER-920151-01/141593515153?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3Dde87202023224998beab30fa8afd1a93%26pid%3D100033%26rk%3D1%26rkt%3D3%26sd%3D141593515153
Hmm. There isn't really a description in that auction, what does it convert the RJ11 to? The low resolution sort of looks like it converts it to...RJ11.
I haven't seen that, but thank you for pointing me in that direction!
Offline magicwuff
« Reply #5 on: Fri, 03 April 2015, 21:25:18 »
I looked through that converter and have found that it only supports certain models of this keyboard. Can anyone help identify the model? It has obviously been rebranded and I don't see any familiar model numbers anywhere. I have tried googling pretty much every number found inside and out (at the tumblr link I provided earlier)
Here is an additional picture of the back.
Any help will be greatly appreciated! Thanks!
Offline ebacho
« Reply #6 on: Fri, 03 April 2015, 22:33:44 »
If the model number isn't printed on the back you might have to open the board up and take a look at the PCB, which usually keeps those identifying marks.
Offline magicwuff
« Reply #7 on: Sun, 05 April 2015, 09:51:34 »
Hi beartato, thank you for the reply.
I have opened up the keyboard and tried looking up all of the numbers found inside, but I haven't been able to extrapolate a model number from them.
The pictures can be found in this blog post: http://ineedtoarduiknow.tumblr.com/post/115350355850
Thanks again!
Offline ebacho
« Reply #8 on: Sun, 05 April 2015, 13:35:46 »
Thanks again!
Judging by the layout and non-stepped modifier keys I'd suspect it's a WY60, which as you know is supported by Soarer's converter.  It's hard to get anything more than that unfortunately, but there's a good chance it'll work with the converter.
Offline Huxley2500
« Reply #9 on: Mon, 06 April 2015, 16:32:03 »
Post what you find out.
