Author Topic: V60 Matias Mini  (Read 2816 times)
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
V60 Matias Mini
« on: Fri, 03 April 2015, 03:56:10 »
Heard good things here and there.
Indoctrinate me into this cult.
Also tell me how great the switches are.
Offline mougrim
Re: V60 Matias Mini
« Reply #1 on: Fri, 03 April 2015, 05:35:44 »
It's good. Pretty crappy keycaps, though. But it's still good.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline ctm
  • Hello, world!
Re: V60 Matias Mini
« Reply #2 on: Fri, 03 April 2015, 17:40:34 »
I enjoy the layout and the switches. The switches are more tactile than Cherry clear or brown IMO. But do note that the stock keycap is thin ABS and if you really need PBT, they are not easy to find (Matias has plan for PBT caps, but they are not available yet).
Coming:
Ellipse Model F F62.
Offline rsadek
  • raging keyboard monkey
Re: V60 Matias Mini
« Reply #3 on: Fri, 03 April 2015, 18:01:42 »
I love mine. It's great :)
Im using the clicky switches which are awesome. The board is bit loud when bottoming out which I hoping to Mitigate with better caps. Matias sells caps now by phone call/email; they should be on the site as well soon. KeyboardCo sells Matias caps as well.
-R
❤️Keeboardz
Offline slaction
Re: V60 Matias Mini
« Reply #4 on: Sat, 04 April 2015, 21:56:24 »
-R
Can you record a basic typing session and upload?
I've been thinking hard about getting a V60 with Tactile switches but the only thing I have to go on is my Matias Tactile Pro board and It doesn't seem likely to me that the sound would be the same coming from the smaller body V60.  The Tactile Pro feels great to type on, but it's a big hunk of plastic that also amplifies the click and the clack, so I really curious how a V60 sounds.
Offline rsadek
Re: V60 Matias Mini
« Reply #5 on: Sun, 05 April 2015, 15:23:26 »
-R
Sure, I will do that. it might take me a little while...but I will try to do a side-by-side so you can get a sense.
-R
❤️Keeboardz
Offline vivalarevolución
Re: V60 Matias Mini
« Reply #6 on: Mon, 06 April 2015, 06:52:09 »
Thinking of jumping in on the Massdrop group buy.  But with quiet switches.  All my keyboards are clicky at the moment.  Need something for those early morning and late night typing sessions.
Offline ctm
  • Hello, world!
Re: V60 Matias Mini
« Reply #7 on: Tue, 07 April 2015, 16:42:02 »
I have been in love with this board for a while but now the fact that it's not programmable and it's unlikely to replace the controller starts to bug me :(
Coming:
Offline rsadek
Re: V60 Matias Mini
« Reply #8 on: Thu, 09 April 2015, 14:26:35 »
-R
-R
I made the recording (see attached file). The order of things is
First Tactile Pro ping test, followed by typing
Second v60 mini ping test, followed by typing
Third v60 touch (light) typing
Fourth Tactile Pro touch (light) typing
* Keyboard Recordings.m4a (1713.2 kB - downloaded 117 times.)
Hope this helps :)
-R
❤️Keeboardz
