Author Topic: Topre Realforce 87U ANSI or JIS?  (Read 2645 times)
Offline derzemel
« on: Fri, 03 April 2015, 09:20:32 »
Hello,
I have a friend in who is in Tokyo until Monday, and Sunday he will have the whole day to himself.
I want to ask him to get me a 55g Topre Realforce 87u Silent.
I am wondering now, what would the JIS layout mean to me, an European who uses ISO and ANSI?
Can I use the extra keys that JIS has?
Thank you!
P.S.: the JIS version seems to be cheaper, at least on amazon.jp
« Last Edit: Fri, 03 April 2015, 09:34:13 by derzemel »
Offline saturnotaku
Re: Topre Realforce 87U ANSI or JIS?
« Reply #1 on: Fri, 03 April 2015, 09:27:20 »
Aside from the large enter key, JIS isn't really comparable to ISO. JIS has a few extra modifier keys to input different kana and kanji characters. Here is what the Japanese Realforce looks like. If you're comfortable using ANSI, I would go for that.
Offline derzemel
« Reply #2 on: Fri, 03 April 2015, 09:33:46 »
yes, I saw a few images. I was actually wondering if I can use those keys (macros, shortcuts, etc.)
I'll modify my original post to make this clear
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #3 on: Fri, 03 April 2015, 10:50:30 »
JIS in your pants
Offline Touch_It
« Reply #4 on: Fri, 03 April 2015, 11:06:23 »
Speaking from a person that Uses ANSI, I think I would hate the layout.  As far as the extra keys I think you would either need a converter to remap the keys, or use software remapping, though for software remapping they layout itself might cause issues.  Someone with more expertise probably needs to weigh in.
