Author Topic: Hello  (Read 3280 times)
Offline kyleking2000
Hello
« on: Fri, 03 April 2015, 14:03:32 »
Hello, I've been lurking as a guest for a little now and finally stopped being lazy and made an account. Anyways I really want to start making boards and knew this would be a good way to start on that journey.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Hello
« Reply #1 on: Sat, 04 April 2015, 00:25:31 »
Welcome to GeekHack! :cool:
Do you have any mechanical keyboards or are you looking to make one as your first?
Re: Hello
« Reply #2 on: Sat, 04 April 2015, 04:50:20 »
Welcome to Geekhack!
Making keyboards to what extent?  Designing and building your own from scratch, or putting together a kit?
Either way, have a look at this question and follow the link for some ideas on where to get started.
Re: Hello
« Reply #3 on: Sat, 04 April 2015, 15:00:13 »
Thank you. I Guess I should have been more specific, I want to start with a kit and maybe one day do something custom.
Re: Hello
« Reply #4 on: Sat, 04 April 2015, 15:02:49 »
I do have boards already and hope to get plenty more in the future.  :))
Re: Hello
« Reply #5 on: Sun, 05 April 2015, 05:57:31 »
Fair enough - I had to ask, some people arrive here with the grandest of ideas (and usually with a lot of technical resources and expertise to back them) ;)
In that case the post I linked is still relevant, but the switches will probably cost you a bit more, and most of the rest you should be able to get in a kit.  Often the electronics (diodes etc.) are already soldered onto the PCB, or that is available as an option.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Hello
« Reply #6 on: Sun, 05 April 2015, 07:48:36 »
Ahh!  Now that's the GeekHack spirit! :thumb:
Re: Hello
« Reply #7 on: Sun, 05 April 2015, 14:28:27 »
Ok thanks  :)
Offline LXXXIX
  • Just remember all caps when you spell the man name
Re: Hello
« Reply #8 on: Mon, 06 April 2015, 18:51:57 »
Hello and welcome to GH! I'm in the same boat about building my first custom board. If you find something you are interested in I'd like to know. Good luck! :cool:
Re: Hello
« Reply #9 on: Sun, 12 April 2015, 10:55:48 »
Thank you. I will definitely let you know when I find something that interests me. Good luck to you as well! :)
