Author Topic: Where can you find matias keycaps ?  (Read 1869 times)
Offline Nikelu
  • Don't read this!
« on: Sat, 04 April 2015, 17:30:51 »
Or cant you?Seems like the stem is really different,so I guess if I buy one I will stick with the stock ones
Offline bcredbottle
Re: Where can you find matias keycaps ?
« Reply #1 on: Sat, 04 April 2015, 17:46:11 »
Matias is making some https://geekhack.org/index.php?topic=45483.270. Those are PBT so if you want colored caps you should wait for those and dye them.
KeyboardCo sells caps in black and white. I don't know what material it's made of. Go to http://www.keyboardco.com/keyboard_search.asp and search "Matias."
Alternatively, you can get an old ALPS board off of eBay or w/e and salvage the keycaps.
