Author Topic: Maximum thickness for ALPS plates?  (Read 4764 times)
Offline FrostyToast
  • Litshoard
« on: Sun, 05 April 2015, 19:00:51 »
I am going to be working on some ALPS projects in the future, however I don't know what the maximum thickness allowed for an ALPS plate is.
Does anyone know what the limit is?
I know according to Cherry spec you can do up to 5mm but only with a special cutout. Would I have to do something like this for ALPS?
Quote from: elton5354
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Maximum thickness for ALPS plates?
« Reply #1 on: Mon, 06 April 2015, 02:47:49 »
You mean the metal mounting plate or the PCB? For the mounting plate; pretty thick probably! There is normally a space between the mounting plate and the PCB which you can fill up, and in theory thr pins only have to get to the other side of the PCB. I don't have one ready atm so I can't measure it, though. I would imagine that this heavily affects typing sound, though. What exactly are you planning, if you don't mind me asking?
Offline FrostyToast
  • Litshoard
« Reply #2 on: Mon, 06 April 2015, 09:38:22 »
I have a couple of things in mind:
1) A 5mm stainless steel switch plate would be heavy as ****.
2) Some people have a fancy plate design where they have two plates combined together; usually both 2mm to add to 4mm. The bottom plate would be metal for that solid feeling and weight, and the top plate would be something like acrylic or polycarbonate for light diffusion.
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Mon, 06 April 2015, 17:02:22 »
Sounds like a gargantuan faff for little reward, mate. If you want to add some wight, might be worth just adding separate weights to it.
Offline jacobolus
« Reply #4 on: Mon, 06 April 2015, 17:54:03 »
If you want the switches to clip in, 1.6mm is about the upper limit. Alps switches actually work better with a 1.6mm plate than cherry switches do. With cherry switches, even 16 gauge steel is sometimes too thick for them to clip properly. For both Cherry and Alps switches, my own recommendation would be to stick to 18 or 17 gauge steel.
With Alps switches and a 1.6mm thick plate, you want to slightly adjust your cutout shapes so you avoid crushing the little plastic “wing” clips. If you plate is too thick and too tight, you’ll end up breaking a lot of them. If you’re soldering everything down to a PCB this isn’t the end of the world, but it can prevent you from desoldering those switches and using them in another context.
You can make a plate as thick as you want, if you adjust your cutout shape to entirely avoid the plastic clips, and just make the plate tight enough to the dimensions of the switch that it’ll be held in by friction. If you want to do that though, you need to make sure your cutting process is very precise and locally accurate, since if you make it too tight you’ll be stuck filing things down by hand to get your switches in, and if you make it too loose they won’t stay. Again, if you have a PCB then it’s not quite as big a deal.
If you want to layer acrylic + steel below, just cut the normal Alps cutouts in the acrylic (which you should be 1.5 mm or 1/16" thick), and then cut slightly larger holes in the steel in a shape which avoids smashing the clips. That should work pretty well.
Alternately, you could use as thick a plate as you like in whatever material, and use a CNC mill to cut a little ledge from the bottom side of the plate for the clips to snap into, in effect making the plate only 1.5mm thick at certain spots where you need, and as thick as you like for the rest.
« Last Edit: Mon, 06 April 2015, 17:57:50 by jacobolus »
