Author Topic: Can someone suggest some mice that will work with this grip.  (Read 5043 times)
Offline thebloody9
I use a palm grip (as shown in the pictures), but I hold the mouse really far back so most of my palm rests on the pad. I am currently using the g502 but it is too narrow for this grip and causes my hand to cramp.
Offline Eziak
Re: Can someone suggest some mice that will work with this grip.
« Reply #1 on: Mon, 06 April 2015, 22:35:36 »
Do you have a local bestbuy? I know at mine they have like... 5-6 mice out that you can try out. If you want to stick with a perfect sensor mouse I'd suggest looking at the steelseries rival. The problem with that mouse with that grip is you might not be able to reach the forward side button with your hand that far back.
Boards:
CM Storm Novatouch
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #2 on: Mon, 06 April 2015, 22:38:08 »
Deathadder
Offline Oobly
« Reply #3 on: Tue, 04 August 2015, 09:27:51 »
MadCatz RAT TE or MMO TE if you need button overload. Both have good sensors and are really comfortable for that kind of grip, with adjustable palm piece.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline daerid
    • Rossipedia
« Reply #4 on: Tue, 04 August 2015, 22:54:25 »
The Func MS-3. I have huge hands and can palm that thing like a basketball.
Offline trizkut
« Reply #5 on: Tue, 04 August 2015, 22:58:08 »
Looks eerily similar to the mionix naos
Offline daerid
    • Rossipedia
« Reply #6 on: Tue, 04 August 2015, 23:03:48 »
Actually that's another great shape that would probably fit OP's bill.
Offline 7Teku
« Reply #7 on: Sat, 22 August 2015, 21:07:59 »
DA, Rival, EC1-A, IME 3.0, Naos 7000 should be all options for you.
