Author Topic: Help getting started with gSchem and gEDA.  (Read 1699 times)
Offline Wulfsta
« on: Mon, 06 April 2015, 18:38:00 »
To preface this, I have no prior experiance designing PCBs. This is also my first post on the forums, so be gentle if I'm in the wrong asking here.
I have designed a layout for a keyboard, and have decided to build a PCB, Plate, and code the firmware. The only thing I cannot do is design the PCB, and, after considering my options, I've decided to use gEDA. Can someone please help me get started with Cherry MX footprints?
Thanks.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Help getting started with gSchem and gEDA.
« Reply #1 on: Mon, 06 April 2015, 18:50:45 »
You seem set on gEDA, but I would suggest KiCAD as there are a couple tutorials, footprints, and repos for KiCAD on here and DT.
