Author Topic: emacs keycap  (Read 4043 times)
Offline Eremox
emacs keycap
« on: Tue, 07 April 2015, 00:49:39 »
Why hasn't there been a group buy with emacs keycaps? I mean there are vim ones...
If image is broken then try: http://imgur.com/zuGCWEE
I do know that it's not the prettiest key design but i bet some of you more experienced could refine it. Both the colors and the logo.
I hope that someone will be inspired to start a GB.
Leopold FC750R | Func KB-460
Re: emacs keycap
« Reply #1 on: Tue, 07 April 2015, 00:54:59 »
The real question is: why haven't you switched to vim yet?
Offline Eremox
Re: emacs keycap
« Reply #2 on: Tue, 07 April 2015, 01:16:41 »
Why would I know lisp so I can customize emacs better than I can with vim and I also think it would be counter productive to learn a new editor when that might slow me down for a few weeks.  ;) Also emacs are for the enlightened ones.  >:D
Re: emacs keycap
« Reply #3 on: Tue, 07 April 2015, 05:19:06 »
Welcome to Geekhack!
You could post this in the keycap ideas thread, or even start an interest check!
Offline Giorgio
Re: emacs keycap
« Reply #4 on: Tue, 07 April 2015, 06:28:46 »
Emacs keycap should be sized 1,25 - bottom row -since it's an operating system?  :D
Offline ttzhou
  • in your base, belonging
Re: emacs keycap
« Reply #5 on: Wed, 08 April 2015, 08:19:44 »
Nah, 1.25u because that's the traditional size of the modifier keys, which you press so much when using it  ;D
Offline Giorgio
Re: emacs keycap
« Reply #6 on: Wed, 08 April 2015, 17:50:41 »
The only key combination useful for emacs is alt-F4
Offline ttzhou
Re: emacs keycap
« Reply #7 on: Wed, 08 April 2015, 20:40:19 »
agreed :P i was poking fun at the sometimes ridiculously long modifier chains though.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: emacs keycap
« Reply #8 on: Thu, 09 April 2015, 10:46:25 »
Code: [Select]
emacs -batch -l dunnet
at least it's good for something  ;D
