Author Topic: Side-printed grey keycaps  (Read 2233 times)
Offline summertimeacid
« on: Tue, 07 April 2015, 07:12:16 »
Hey guys, new to the forum. I'm looking for some side-printed cherry mx keycaps preferably in grey. I have the CM Storm Quick Fire XT Stealth and was looking to get some grey keycaps to slot in
I've only managed to find white or black as far as I can see
Cheers
Offline MrFex
Re: Side-printed grey keycaps
« Reply #1 on: Mon, 13 April 2015, 12:34:46 »
Hi
This link might interest you. Didn't find gray ones off the bat, but I'm sure that it because I am not chinese ;)
http://jikaism.tmall.com/category-757345636.htm?spm=a1z10.5-b.w4010-3081235393.16.pEl5Bi&search=y&catName=%BC%FC%C3%B1%D7%A8%C7%F8#bd
Found a lot of "side engraved" keycaps at this store, but there are many others. I use Google Chrome (Rightmouse > Translate to English) for convenience.
Offline MrFex
« Reply #2 on: Mon, 13 April 2015, 12:39:22 »
Correction, this is now the place to be:
http://www.maxkeyboard.com/max-ansi-104-key-cherry-mx-full-replacement-keycap-set-blank.html
MaxKeyboard offers custom printing options, they charge *only* $15 more for a side-print. Also you can choose from ANSI and ISO.
These guys know what people want, crazy right? :)
If only they offered custom ABS backlit keysets ....
« Reply #3 on: Wed, 15 April 2015, 18:05:52 »
Awesome man! Thanks so much for your help
