Author Topic: Question: If it is possible to make a keyboard like this?  (Read 3160 times)
Offline simonyunhe
« on: Tue, 07 April 2015, 18:01:58 »
Hi, I want to make a keyboard with this layout, if it is possible?
If the answer is posative, whether the GH60 PCB support it or not?
Thanks.
« Last Edit: Tue, 07 April 2015, 18:04:58 by simonyunhe »
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
Re: Question: If it is possible to make a keyboard like this?
« Reply #1 on: Tue, 07 April 2015, 18:03:17 »
Thanks.
FTFY, use the actual image links not the imgur preview links.
Also that layout is possible if you made your own board but not possible on the GH60.
« Last Edit: Tue, 07 April 2015, 18:05:21 by Joey Quinn »
Offline simonyunhe
« Reply #2 on: Tue, 07 April 2015, 18:06:00 »
Thanks.
FTFY
Thanks man, just figure out where goes wrong with the pic.  :p
Offline simonyunhe
« Reply #3 on: Tue, 07 April 2015, 18:26:54 »
I still do not figure out where goes wrong, the GH60 seems like support this one? Is this barbecue the Fn key's position is not fit for the PCB?
« Reply #4 on: Tue, 07 April 2015, 18:48:18 »
The issue is the 1.25u directly to the left of the Fn.
Offline simonyunhe
« Reply #5 on: Tue, 07 April 2015, 19:07:03 »
Okay i see, thanks so much. :thumb:
« Reply #6 on: Wed, 08 April 2015, 06:24:01 »
That's a cool layout.
Another issue you would have is finding key caps for it
Offline KatzenKinder
« Reply #7 on: Wed, 08 April 2015, 17:45:42 »
Shouldn't be too hard with all of the DSA options available. I know granite has most if not all of those sizes / keys.
Offline simonyunhe
« Reply #8 on: Wed, 08 April 2015, 22:26:03 »
You are right, just bought the Granite set from Massdrop.
