Author Topic: One key on a kinesis advantage is acting up, what could be wrong?  (Read 1865 times)
Offline jonasbrossuck
the left arrow key on my keyboard(cherry brown switch) is acting up in a weird way...
the malfunctioning has nothing to do with the OS that it's running(i think), but i'm running linux, and when _any_ application, in this case, firefox, is open, and i press the left arrow key, it brings up the unity menu "type your command" (like when the alt key is pressed), but if i press the left arrow key more times, then firefox navigates to the previous page(as if ctrl+left arrow key is pressed)
i'm guessing that by pressing the left arrow key, something is messed up so the signal for ctrl, alt, and left are sent? how can i possiblly fix this?
in Ubuntu, the output of running  the command,
Code: [Select]
    showkey -a
in ubuntu, for pressing up, down, right, left, is
Code: [Select]
   ^[[A 27 0033 0x1b
           91 0133 0x5b
           65 0101 0x41
    ^[[B 27 0033 0x1b
           91 0133 0x5b
           66 0102 0x42
    ^[[C 27 0033 0x1b
           91 0133 0x5b
           67 0103 0x43
    ^[[1;3D 27 0033 0x1b
           91 0133 0x5b
           49 0061 0x31
           59 0073 0x3b
           51 0063 0x33
           68 0104 0x44
Offline jacobolus
Re: One key on a kinesis advantage is acting up, what could be wrong?
« Reply #1 on: Wed, 08 April 2015, 18:51:22 »
You should open it up and take a look at the pcb, and ideally poke around with a multimeter. Sounds like a couple of your traces are shorted together. If you take a high resolution photo of the relevant part of the pcb and post it in the living soldering thread, someone might be able to spot the problem.
« Reply #2 on: Thu, 09 April 2015, 02:13:43 »
i'll try to do that once i find access to a screw driver, thanks!
