Author Topic: Possible to build square layout?  (Read 3518 times)
Offline kikim792
« on: Thu, 09 April 2015, 16:25:58 »
Hi,
I am interested in building a keyboard with a square grid layout. Couple of motivations behind are:
- Other than a historical reason, modern keyboard does not need to follow legacy layout.
- With square layout, it would be easier to enter numbers using keys UIO/JKL, etc
Is it possible to build one using commercially available kits? Any pointer to get me started is appreciated.
Thanks.
KK
Offline plegnic
  • Treble Booty. Bass Guitar.
Re: Possible to build square layout?
« Reply #1 on: Thu, 09 April 2015, 16:31:14 »
ortholinearkeyboards.com. Looks like the Atomic might be more what you are looking for?
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
Offline kikim792
« Reply #2 on: Thu, 09 April 2015, 16:43:54 »
@plegnic,
It's nice except it is missing the top row for ESC and function keys.
Thanks.
« Reply #3 on: Thu, 09 April 2015, 16:46:06 »
Another option would be a point of sale board, such as the Access one in this classified.
Offline SonOfSonOfSpock
« Reply #4 on: Thu, 09 April 2015, 16:47:46 »
If you are okay with scissor switches, your picture looks a lot like the TypeMatrix 2030 keyboard. I know that doesn't answer your question about building a keyboard though.
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Fri, 10 April 2015, 10:03:20 »
You definitely want separate halves, or a at least a hole between them. The grid forces quite aggressive ulnar deviation otherwise, if you touch type using the standard technique. It's not that bad on a low-profile keyboard, such as the TypeMatrix, but sucks with more profiled, tall keys.
There are plenty of POS matrix keyboards. Usually from Access-IS or Tipro. The latter usually support daisy-chaining. There's been the Humble Hacker project and later GH36x2 as well, but it seems samwisekoi has abandoned it…?
I don't see the point of not going the whole way to a columnar layout with dedicated thumb clusters though, unless you're on budget and want to reuse existing parts.
Offline Oobly
« Reply #6 on: Fri, 10 April 2015, 10:55:50 »
+1
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline qisqaqas
  • I'm just a maker wannabe.
« Reply #7 on: Fri, 10 April 2015, 22:30:50 »
Possible. Check this guy's project here. He did something similar
This message is made by 100% recycled electrons.
