Author Topic: Mionix Naos 7000 on Massdrop again  (Read 4179 times)
Offline Axollott
« on: Fri, 10 April 2015, 01:50:32 »
so, subject title is self explanatory
https://www.massdrop.com/buy/mionix-naos-7000
I'm having trouble to decide if i should buy this, my hands are not huge but i neeed a decent palm grip mouse. I'm currently using a Logitech Anywhere MX that ain't that bad but it's not for gaming or long hours of use.
I'm also interested in the Logitech G502 Proteus Core since Logitech has given me superb Costumer support with the first Anywhere MX that started giving double click problems in the left microswitch. And the Roccat Kone XTD looks amazing too... so... choices, choices, choices.
Offline ander
  • I type, therefore I am
Re: Mionix Naos 7000 on Massdrop again
« Reply #1 on: Fri, 10 April 2015, 02:46:04 »
Wow, these are awesome mice—highly ergonomic, hi-res (7K dpi), fast (onboard ARM CPU), millions of LED options, seven programmable buttons... It's an excellent value at full price, and this is 20% below the best price I could find anywhere else. Seems like a no-brainer.
Offline Axollott
« Reply #2 on: Fri, 10 April 2015, 02:52:16 »
It is really tempting. And since they don't sell em in my country (Tacoland) i could sell it at a decent price if i get fed up with it. REALLY tempting.  :p
Offline ed_avis
« Reply #3 on: Fri, 10 April 2015, 06:51:16 »
Why does all 'gaming' hardware have to be so ugly?
Offline Ludovician
« Reply #4 on: Fri, 10 April 2015, 08:37:37 »
Is the DPI on this thing adjustable? I imagine it wouldn't be too hard to switch between 6.4k (what I currently use) and 7k, but ideally I'd like to set both to 6.4k.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline Axollott
« Reply #5 on: Fri, 10 April 2015, 12:32:08 »
It is, it has 3 customizable levels.
Offline Axollott
« Reply #6 on: Fri, 10 April 2015, 12:35:52 »
Function over aesthetic?  Which mouse would you consider beautiful?
I have friends that venerate the Apple mouse which I consider it has inferior ergonomics to a simple 🐭 like the Microsoft intellimouse models and it doesn't really glide smoothly, it has a lot of drag on most surfaces.
Offline Ludovician
« Reply #7 on: Fri, 10 April 2015, 18:19:59 »
So... not fully customisable? That's disappointing.
Typing speed:
My collection:
Pending:
Infinity kit
Offline Axollott
« Reply #8 on: Fri, 10 April 2015, 19:24:38 »
It is fully customizable! It has 3 selectable memory slots ...
Offline njbair
    • nickbair.net
« Reply #9 on: Fri, 10 April 2015, 19:27:45 »
That Apple mouse is garbage.
Source: used an Apple mouse all day.
My boards:
Offline Axollott
« Reply #10 on: Fri, 10 April 2015, 19:54:13 »
 :))  :))  :))   It is!
Offline nightdriver
  • life is like t. rex
« Reply #11 on: Fri, 10 April 2015, 21:41:37 »
my problem with pricey mice is they usually only last me about a year before the button gives out.  so i usually just go for something cheap.
Offline Axollott
« Reply #12 on: Sat, 11 April 2015, 01:51:47 »
What do you mean specifically? You can replace the microswitches when they give up. And since you are already doing the effort you can upgrade them for some Japanese made Omrons (which I'm already waiting for a shipment). You'll be able to use the mouse for at least one more year per switch change (since the Japanese ones are better made than the Chinese that every OEM uses, I'll bet way more than that). It should require only a simple soldering job.
If you have any unused pricey mouse you don't want to repair (I would call it maintenance)  please send it my way, so I can replace the switches, test it and if it doesn't fit my needs or taste I can donate them to some charity or NGO. I'm in under developed Mexico. If you do decide to repair them it would be awesome anyways, you will save money and reduce your contribution to our beautiful planet's pollution.
Offline ander
« Reply #13 on: Sat, 11 April 2015, 02:03:44 »
It's not ugly. It's sinister-looking. Like the Batmobile. Try saying "I'm Batman" with a soft, pretty voice. It doesn't work.
« Reply #14 on: Sat, 11 April 2015, 02:04:40 »
Whelp, I just snagged one.  My Mionix Naos 5000 is nice, but is ready to be replaced.
Offline Axollott
« Reply #15 on: Sat, 11 April 2015, 02:20:36 »
What's wrong with it? I've seen several people commenting on grabbing  a new one because their preceding one is dying or giving up but they never mention the specific cause of failure.
  I'll buy it tomorrow anyways, it's a nice promotion.
« Reply #16 on: Sat, 11 April 2015, 02:23:39 »
Nothing's really wrong with it.  Some of the rubberizer is peeling and on occasion the sensor decides to track oddly, but that's due to dust or something getting on the sensor lens.  I just know the 7200 uses a better sensor and it's time for an upgrade.
Offline Axollott
« Reply #17 on: Sat, 11 April 2015, 02:51:13 »
Oh good to know! I really expect it to last. Thnx.
Offline nightdriver
« Reply #18 on: Sun, 12 April 2015, 00:08:29 »
i don't yet trust myself desoldering and soldering.  one of those skills i've been meaning to learn!
Offline Axollott
« Reply #19 on: Sun, 12 April 2015, 20:12:06 »
You should try it out, don't leave any learning you can do today for tomorrow. Tomorrow we'll all be skulls.  :))
