Author Topic: Bought Apple Adjustable; switches feel...scratchy?  (Read 1368 times)
Offline bcredbottle
« on: Fri, 10 April 2015, 19:53:59 »
I got an old Apple adjustable. It's generally in good shape but it feels scratchy when I push the keys down. It also feels like it takes a little extra time for the switches to rebound to their original position after being pressed. Any recommendations for what I should do?
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Bought Apple Adjustable; switches feel...scratchy?
« Reply #1 on: Fri, 10 April 2015, 20:05:56 »
I found one in the wild and thought it was a rubber dome the alps felt so bad. I'm not a fan.
If you like the board enough you could always try to disassemble and clean it.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Fri, 10 April 2015, 20:48:32 »
Does this use Alps switches? If so, I made a tutorial for cleaning them out:
Offline jacobolus
« Reply #3 on: Fri, 10 April 2015, 20:57:26 »
It’s not Alps SKCM switches, but rather SKFS http://deskthority.net/wiki/Alps_SKFR/SKFS
They’re not the same to disassemble, and I’m not sure whether it can be done without desoldering.
I’m not a huge fan of the switches, but if they’re scratchy, that means they’re in poor condition (the same thing can happen to any other type of 25-year-old switch). You can’t fairly judge the switches by the particular ones you have in front of you. If you want to give them a fair shake, find a closer to NIB keyboard. (Personally I wouldn’t bother though; there are much nicer switches out there.)
If you want to fix this board up, you could take everything apart, desolder all the switches, disassemble them, thoroughly clean the dust/dirt of of them, and possibly add some lubricant. It would be a huge pain in the ass though. Not worth the trouble IMO.
« Last Edit: Fri, 10 April 2015, 21:00:39 by jacobolus »
Offline bcredbottle
« Reply #4 on: Wed, 15 April 2015, 09:51:12 »
« Last Edit: Wed, 06 October 2021, 13:59:59 by bcredbottle »
